Intake manifold flap
347 Apr 7, 2009
  1. 347
    347 Active Member Team Daytona VCDS Map User Audi S3 DSG
    362
    59
    hi , audi a3 2.0 tdi 04
    on way to work this morning the yellow engine light lit up on dash and has stayed on .
    done a scan and this has come up
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 G HW: 028 101 136 4
    Component: R4 2,0L EDC 0000SG 5705
    Revision: 12345678 Serial number: AUX7Z0CNFN502Q
    Coding: 0000072
    Shop #: WSC 66565 257 00032
    2 Faults Found:
    19558 - Motor for Intake Manifold Flap (V157): No Signal
    P3102 - 000 - -
    Freeze Frame:
    RPM: 819 /min
    Torque: 24.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.14 V
    Bin. Bits: 11000100
    Torque: 140.0 Nm
    Torque: 0.0 Nm
    17075 - Fan 1 Control Circuit: Short to GND
    P0691 - 000 - -
    Freeze Frame:
    RPM: 798 /min
    Torque: 26.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.14 V
    Bin. Bits: 11000100
    Temperature: 34.2°C
    Duty Cycle: 9.6 %
    Readiness: 1 1 0 0 0
    the car still drives what is this flap , where about does it live and can i perform any other tests
    thanks john
  2. Gti Jazz Blue
    Gti Jazz Blue Active Member VCDS Map User
    1,655
  3. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    am i right in saying that the flap should be shut when the engine is of ?
  4. Wai-Fan
    Wai-Fan Member
    530
    I had this problem about a month ago, before the errors came up, I had a loud buzzing noise coming from the engine area, which turned out to be the IMF.
    It also affected my aircon as well for some reason so had to get it replaced.
  5. Gti Jazz Blue
    1,655
    Yes because it blows the fuse that supplies the fan controller.
    Paul
  6. grannyjane1970
    grannyjane1970 New Member
    i had this problem two days ago mechanics where able to close flap,saved me a fortune
  7. grannyjane1970
    sorry just new to this site my reply was to the manafold flap
