Instrument Swap Troubles
Paul @ Unit 9 Remaps Aug 15, 2013
  1. Paul @ Unit 9 Remaps
    Paul @ Unit 9 Remaps Site Sponsor Site Sponsor
    2,035
    132
    Trying to fit some new/used clocks to the car. Need the pins for the current and new/used clocks so used vag commander and heres the results
    Old clocks info
    ECU code 01400
    Server Code 00443
    i then click next and get
    Pin 00001
    New/Used clocks info
    ECU code 01400
    Server Code 00414
    Pin 00001
    Hoping this makes sense. then i follow this guide from Ross Tech
    Immobilizer III Immobilizer Swapping (Instrument Cluster) - Ross-Tech Wiki
    Now when i get to..........................
    [17 - Instruments]
    [Login - 11]
    For the following procedure, use the PIN of the REPLACEMENT (NEW or USED) instrument cluster.
    4-digit PIN
    Enter zero followed by the 4-digit PIN directly in the Login field. For example, if your PIN is 1234, enter 01234.
    [Do it!]
    i get invalid code' ive tried all the codes thats in the first part of the post and none works. am i missing somthing :mad:
  2. hades-
    9,481
    646
    looks like its not pulling the skc code out
  3. Paul @ Unit 9 Remaps
    2,035
    132
    what i was thinking. tried through the ECU and get an error. abit fed up
    Is there anyway or repairingn the eeprom for the cluster through vcds or the likes
  4. hades-
    9,481
    646
    is it a snide vag commander ?
  5. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,819
    197
    If you have an a4 you do not plug in clone pin readers!!!
    NHN likes this.
  6. @udi A3
    1,819
    197
    your vag commander sounds iffy, should have to just read eeprom and it will give pin after the hex screen populates.
    for an a4 better off removing the clocks and reading the eeprom on the bench.
    where abouts are you based?
  7. @udi A3
    1,819
    197
    if you can post a hex dump i can decode the skc from it if that helps
  8. Paul @ Unit 9 Remaps
    2,035
    132
    whats the easiest way to post a hex dump'
  9. @udi A3
    1,819
    197
    I dont have much experience with the a4, but if your clone cable with read or allow you to save the eeprom dump your halfway there. I wouldnt suggest writing anything at all with it though, read only, if your lucky.
