Instrument Problems
fireblade Sep 29, 2004
  1. fireblade
    fireblade New Member
    Hi
    Could anyone help me with a problem with the dash on my 99 pre facelift S4?.
    The fuel gauge is acting like a rev counter, moving up and down with the revs causing the "miles left per tank" reading on the display panel to do the same. Also the speedo is not working and the milage is not clocking on the display. The same problem occured a few months ago but fixed itself after I switched the ignition off and restarted it, this hasn't worked this time.
    Does anyone know if there is a common sender for both the fuel gauge and speedo which could be faulty, or in the worst case the rough price of a new dash.
    Cheers for any help
    Jim
  2. leespears1
    leespears1 Member
    261
    do a seacrh on this, theres loads on the forum about this.
  3. Mutinyno9
    Mutinyno9 Member
    248
    same thing on my A4, i had a bad fuel sensor.
  4. fireblade
    Cheers!
    The speedo etc is now working again for now but i'll have to try and sort it out.
    The speedo seems to go off first, like a bad connection then when completaly dead the fuel gauge goes mental.
    Would the fuel sensor affect the speedo aswell as the fuel gauge, the car seems to be running fine otherwise.
    Would this show up on a VAG.COM.
    Thanks again
    Jim
  5. Mutinyno9
    Mutinyno9 Member
    248
    so both your speedo and fuel are on the fritz? if so, sounds like something in the cluster
  6. fireblade
    That was my first thought, hope its a connection and not the cluster, its still working fine for now
    Jim
