Instrument lights flick on and off
yani Jul 7, 2009
  1. yani
    yani New Member
    21
    when i turn my lights on the Instrument lights somtimes flick on and off, when i try to adjust from the dimmer it doesn't work very well. i had this prob on my MK1 golf which was sorted after i fitted a new dimmer switch.
    has anyone else has this problem and know the fix ?
    I don't have auto lights.
  2. DeckedS3
    DeckedS3 Well-Known Member
    878
    301
    Is it more of a dim up and down? when you go through trees or something?
    Mine does it when direct sunlight hits the cluster (my main beams don't turn on) sometimes the speedo numbers dim up and down and the needle remains lit. If thats what your talking about it's suppose to do it....
    Hope that helps :thumbsup:
  3. yani
    yani New Member
    21
    not a dim up and down its a sudden on off as if there was a loose connection.
  4. dipstic
    dipstic Member
    384
    Good its not just mine then,numbers dim but the needles remain lit and yep damn tree shadows on a sunny day:icon_thumright:
  5. Felix A3
    Felix A3 New Member
    23
    I had the same problem with mine. Turned out to be a dry solder joint where the main connector for the rheostat attaches to the circuit board. If you remove the main lighting switch from the facia you can then detach the rheostat (dimmer switch) from it, carefully take the rheostat apart and re-solder the connections on the board. Re assemble and voila!
  6. yani
    yani New Member
    21
    just noticed this happens with the lights off too :uhm:
  7. Aspen
    Aspen Member VCDS Map User
    153
    9
    OMG I just logged in to put a post like this on!!!
    my numbers dim under trees too, but not all the time. I think it's supposed to be a some kind of auto dimmer thing. But the needles don't change, just the dials. weird.
    Anyone know more about this. I'm just going to plug vagcom in and see if there's a fault.
  8. yani
    yani New Member
    21
    mine has no auto head lights, the dash lights just flick on / off like its a loose wire, never noticed it dim. being day or night headlights on or off makes no diffrence.
    defo a loose plug or somthing..........
  9. Felix A3
    Felix A3 New Member
    23
    Is your instrument backlighting usually on all the time, irrespective of whether the lights are on or not?
  10. pns2007
    pns2007 Moonstone Grey VCDS Map User
    687
    64
    You can change this using VDS coding so that both needles and backlights stay on all the time. I had the prblem that with my roof down and the glare the cluster looked a bit dull, so I changed the settings so its on all the time
  11. Staz
    Staz is a retronaut Moderator VCDS Map User
    6,206
    67
    Nav screen changes brightness with the ambient light too.
    Yani, try giving the area around the dimmer switch a couple of bangs, it may show more symptoms.
