Installing kufatec harness
jimbooboo Oct 2, 2013
  1. jimbooboo
    jimbooboo Member
    153
    9
    I am going down the halogen to xenon route and have just routed the kufatec harness through the bulkhead ready for headlights this weekend..
    I followed a guide that fed it in via the left hand side of a car into the drivers side which was left hand drive.. As mine is right hand drive its on the passenger side.
    The question is.. do i now need to route the harness though to the drivers side to plug it in? Or is that look still on the left hand side of the car despite being of opposite wheel drive.. I just want to know before I start looking for a connector that isnt going to be there etc
    here is the guide I have roughly followed
    DIY: Halogen to Bi-Xenon - Kufatec Interface
    Cheers, James
  2. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,764
    660
    All the connectors/relays will be on the drivers side of the car for UK models
  3. SinghB7
    SinghB7 Active Member
    523
    68
    You will have to route it on the drivers side of the car.
    I'll give you a tip, i used this way to do mine:
    remove the panel under the steering wheel (3x 8mm bolts)
    next install your loom then the wire to go in the cab, route it along under the foam strip
    on the right hand side of the ecu, will be a grommet just under the pipe if i remember
    make a hole small enough for the wires to go thru but not too big or water will enter your footwell
    then poke the wires thru the grommet and you will see them coming from under the steering wheel area (best to have 1 person pushing the wire thru and 1 to look for it coming thru under neath)
    next once the wires are thru just push fit them into the plug as mentioned in the guide.
    its really straight forward, if you need any help drop me a message.
  4. hades-
    9,481
    646
    you may need a new cem to stop any flickering of the lights
  5. jimbooboo
    jimbooboo Member
    153
    9
    Can you elaborate on this?
    Also, im using HID kit with D1S bulbs for the conversion..
  6. hades-
    9,481
    646
    some central electrics modules wont take the codeing for xenon
    the module your gona connect the 2 wires to
    so you may need to change it
  7. jimbooboo
    jimbooboo Member
    153
    9
    Its a cabriolet S-line ?
    That make a difference?
  8. hades-
    9,481
    646
    makes no diffrence
    plug vcds in and post part number
