Installing HU and subs/amp. help needed please
xCoupexAshx Aug 24, 2010
  1. xCoupexAshx
    xCoupexAshx All Torque
    hey there
    i had a look through the forum, but am still a lil confused, so i thought id ask =]
    i wanna fit my apline ida-x001 HU to my 98 a3 1.8t and i have 2 jbl subs running off a 1100w T1 amp. Basically i wanna kno wat i need to install it, ie leads n adapters? and how hard will this be to install?
    ive found these bits so far, are these suitable/ correct? and wat else do i need. thanks in advance
    wiring kit VIBE 8 AWG GAUGE FLAT 1500w AMP AMPLIFIER WIRING KIT on eBay (end time 31-Aug-10 13:53:50 BST)
    HU facia adapter CELSUS AUDIO BLACK FASCIA FOR AUDI A3/S3 (8L) 96 ON on eBay (end time 18-Sep-10 17:59:10 BST)
    HU removal keys PC5-93 Audi TT A3 A4 A6 Stereo Release Keys on eBay (end time 20-Sep-10 09:51:18 BST)
  2. AndyMac
    9,832
    46
    the removal keys and fascia adapters are correct, but I doubt you wanna run an 1.1kW amp using 8 gauge cable. 8 gauge is 40 amp, so perfect for 300-400wrms, if the amp is truly that powerful then you'll need at least 4 gauge.
    You'll also need a antenna amp adapter to power the aerial amp:
    ISO Active Aerial adaptor - Fitting Adaptor
    Presumably you are bypassing the puny rear/sub amp so you won't need the additional PC9-404 amp adapter.
    Running power through the bulkhead is pretty easy, instructions are here:
    http://freepdfhosting.com/37841f9301.pdf
  3. xCoupexAshx
  4. AndyMac
    9,832
    46
    Yes that's more like it
  5. xCoupexAshx
    thanks very much mate. hopefully get em installed at the weekend =]
