Installing Bi-XENON OEM on Audi A3 2.0 TDI from 2005
abpostelnicu May 6, 2010
  1. Hello guys,
    i'm planning to install oem bi-xenon on my 2.0 TDI Audi A3 2005. Till now i've bought the 2 headlights including the xenon bulbs and the electronics units, the command unit - 1T0 907 357, the two leveling sensors and the wires. I will also have to buy the headlight switch. My question is if there is something else that i need to take into consideration before i will put up everything.
    Thank you!
  2. NHN
    29,594
    1,782
    That module shows for the VW Golf & others, I cant guarantee this has any differences between brands, for sure it doesnt show up on the 8P chassis in ETKA that I can see.
    Also what version of central electrics is yours?
  3. I don't know what version i have my vin is wauzzz8p35a016162 where do i have to look in etka?
    Thanks!
  4. NHN
    29,594
    1,782
    You will need to login to module 09 & check this.
  5. isn't there a way to check it from etka? :(
  6. NHN
    29,594
    1,782
    Do you have vin lookup, doubtful, so unless you want to take your trim above your footwell of to visually check or ring your dealer & ask, then thats the only other way.
  7. what code should it be in order for it to work?
  8. YES i have a vin lookup capable ETKA ;)
  9. mine is 8P0-907-279- K
  10. NHN
    29,594
    1,782
    Which version are you using for vin lookup, 7, 7.1 or 7.2 & is it the Tecar version?
    Yes thats fine, Byte 21 sets the headlight type, just have to rewire.
  11. Well i'm using ETKA 7.0 with all it's updated :), do you think that there is a posibility to make the bi-xenons adjust from the button inside the cabin, like the halogen ones do?
  12. NHN
    29,594
    1,782
    7.0 doesnt include vin lookup without a crack or dealer login info.
    I dont get that comment at all after you said about installing the kit, why on earth would you want to control the lights via the manual dial in dash when the whole point of the sensors, module & headlights is to do it automatically, rather pointless doing the mod if you want manual control.
    Anythings possible in life, you just have to find the way to do it, but if you want auto aswell then no, I wouldnt even bother, uses different motors & headlights.
  13. OK, so i'm a bit dissepointed, i've installed today the kit but my central electronics unit is to old, and doesn't have the encoding for bi-xenon. Apparently mine is 8P0-907-279- A, my question is from where can i buy a newer and updated one.
    Thanks!
  14. NHN
    29,594
    1,782
    Huh, but you said last night it was a K????
  15. YES, this is wahat ETKA shows me 8P0-907-279- K but when i've connected vag-com and went on central electronics module the big surprise came: 8P0-907-279- A
  16. NHN
    29,594
    1,782
    Enough said lmfao :whistle2:
  17. so, what aprt number should i buy this time?
  18. Khufu
    Khufu Well-Known Member
    5,704
    31
    a K revision supports Bi-xenon for sure (its a highline module as opposed to midline you have), the only problem is it is probably not a direct swap for your A revison module. You would to examine the wiring diagrams for both modules & swap some of the wires.
  19. Khufu
    5,704
    31
  20. Well i'm Romanian and i live in Romania :D
  21. NHN
    29,594
    1,782
    You need to check your vin with a dealer instead of guessing with your etka that seems to be reporting the wrong data about your car & see what parts supersede & maybe take a chance as I have before on eg. gateway module.
    But your central electrics is an A that supersedes to a D which then doesnt go anywhere & is a basic board, so you are either stuck on D which I dont think will help or you take a chance & get an F or K or even P & see if you can fit this, your choice but they're not specifically for your car, but as people very well know alot of parts on my car arent for it either lmfao.
  22. Last edited: May 7, 2010
  23. Any ideas?
  24. NHN
    29,594
    1,782
    REDIRECT,8P0-907-279-23-B.LBL,8P0-907-279-E ; 23 Byte (Basis)
    REDIRECT,8P0-907-279-23-H.LBL,8P0-907-279-F ; 23 Byte (Highend)
    REDIRECT,8P0-907-279-23-H.LBL,8P0-907-279-H ; 24 Byte (Highend)
    REDIRECT,8P0-907-279-30-B.LBL,8P0-907-279-J ; 30 Byte (Basis)
    REDIRECT,8P0-907-279-30-H.LBL,8P0-907-279-K ; 30 Byte (Highend)
    REDIRECT,8P0-907-279-30-H.LBL,8P0-907-279-L ; 30 Byte (Highend)
    REDIRECT,8P0-907-279-30-H.LBL,8P0-907-279-N ; 30 Byte (Highend)
    REDIRECT,8P0-907-279-30-H.LBL,8P0-907-279-P ; 30 Byte (Highend)
    You need a highend board, I cant guarantee they will plugnpray with your car once coded, may have to move wires, a risk, but isnt life just 1 big risk.
  25. NHN
    29,594
    1,782
    Whose NHM & LE? :whistle2:
  26. drsilviuro
    drsilviuro Member
    121
    And if you install the P, you will be left with a X-mass tree :laugh: The rest I don't know.. cause NHN won't share :whip::lmfao:
  27. I've uploaded here what i' have managed to do till now. I can have flashes on bi-xenon, i have DRL that are open the entire period when i have the ignition put on, i have normal xenon range and bi-xenon range. This is a movie with what i've managed. My question for Nigel is if i buy this button and i won't change the bornetz it will fit: http://cgi.ebay.co.uk/ws/eBayISAPI....318187&ssPageName=STRK:MEWAX:IT#ht_2712wt_939
    A short clip.
    http://www.filefront.com/16390013/bi-xenon setup.mp4
    Also i figured that i can use some resistances in order to trick the ecu to think that on the DRL sockets he has 55W bulbs, i can do that by installing some 50W resistances but then another problem occurs, these kind of resistance generates a lot of heat and really i don't know how to dissipate it fe without using some radiators.
  28. Khufu
    5,704
    31
    I'm not sure he knows why LOL - Audi transfered the coding across and it worked even thought doing it himself to the same coding it didnt work!
  29. NHN
    29,594
    1,782
    Dont be silly, when I know you'll know.
    Yes I still need to compare codings & adaptions, once done & I find the discrepancy then I will report back but I am atm thinking there's a hidden step to enable certain things on the module, maybe not, but I've enabled some other boxes & the problem hasnt returned, but will play later.
  30. drsilviuro
    drsilviuro Member
    121
    So if I go with the module to the dealer, they can sort it out?
  31. v1raj
    v1raj Member
    309
    20
    Bump...
    influxsg, any updates with this as its something i would be looking to do in the future.
  32. NHN
    29,594
    1,782
    Bump???
    Why do you need to know if he did it or not, its been proven already to be able to install bixenons etc as I've updated several now using certain modules & wiring changes.
  33. v1raj
    v1raj Member
    309
    20
    Hi NHN,
    I am interested to know how the final price for carrying out this update? i.e parts, labour etc..
  34. NHN
    29,594
    1,782
    That has alot of variables & too many to answer overall in 1 reply, if using/buying from dealer than its a 2k parts list with sensors, headlights, maybe more if updating modules already on car, plus maybe a 1-2k labour charge dependent on what they do overall, if buying 2nd user from ebay etc then could be as low as £6-700, but chances of that are low, let alone the labour you would spend on the job.
    I'm basing the above reply on fitting it as it should be as in axle sensors, correct modules for proper coding.
    Great upgrade for sure, but can become expensive, but one I always think its very worthwhile.
  35. v1raj
    v1raj Member
    309
    20
    Thanks for the info NHN, much appreciated.
    You may have seen one of my recent threads:
    http://www.audi-sport.net/vb/showth...hat-i-m-looking-for...-What-do-you-guys-think
    Installing xenons would be at the top of my list of mods so doing quite a bit of research into it. I've found these bi-xenon headlights that include the ballasts:
    http://cgi.ebay.de/2X-ORIGI-XENON-B...Item&pt=Autoteile_Zubehör&hash=item23066f573d
    They'll alone will cost aroung the £530 mark :faint: I guess it's a matter of keeping an eye out for bargains...
  36. NHN
    29,594
    1,782
    That is a bargain, dealer is £1400-1500.
    Also make sure you get the headlights for your country as lhd & rhd are different.
  37. v1raj
    v1raj Member
    309
    20
    Funds are a bit low at the moment as im on the verge of purchasing the A3 in my other thread. May have to sell one or two things to get these.
    Once i have acquired all the parts needed for the job, are you able to recommend anyone to fit/code everything? (From your comment earlier suggesting you have updated a few, i'm guessing you are able to do this??) If so, how much do you charge and how long roughly does the installation take?
    Thanks for all your help.
  38. NHN
    29,594
    1,782
    Yes I can do, where abouts are you.
  39. v1raj
    v1raj Member
    309
    20
    Based in Northampton
