Installing a 12v socket into glovebox - possible?
nicksa3 May 25, 2011
  1. nicksa3
    nicksa3 Member
    35
    Hi,
    I hate having to charge phones etc, using the 12v socket in the centre console - can't stand wires trailing everywhere. I was wondering if it possible to fit a socket into the glovebox? My main concern is whether there is enough space behind it?
    Also, what would the best method of getting power to the glovebox be? At the moment, my plan is to piggyback off the existing socket and try and feed the wires up. Or would it be easier to take a new feed from the fusebox and run the cables behind the dash?
    Thanks.
  2. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,459
    597
    There was an option available to have the 12v socket installed in the boot of the car. You could get the part number for this, piggy back it off the existing, cut a hole in the glove box and secure it - job done!
  3. Ash187
    7,496
    744
    I like the idea of this. sorry cannot really help you but I can say that most would advise to get the power from the fuse box.
    In my MK4 Golf there was a 12v socket in the boot, and im pretty sure it had its power running separately from the one inside the car... does anyone know if our A3's that only have one 12v socket in the car might have another unused fuse that can be used for this?
    Also as for the space behind the glove box... there isnt loads of space but if you install it in the side of the glove box like the ipod adapters then you might get away with it, just leave enough cable for the glove box to come out without pulling on the power cable.
    I'll look into doing this when i get some time, hopefully we can compare notes then.
  4. nicksa3
    nicksa3 Member
    35
    Thanks. I'm not too worried about getting the socket -just ordered a generic one off ebay. It's whether there is the space behind the glovebox. I'm being lazy basically; I'm hoping someone will know the answer, saving me the job of finding out myself!
  5. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,163
    1,123
    12v?
    Bahh, get some 240V in there. :)
    Take the live feed from the current lighter or from the fuse box or from the battery. Its up to you, just make sure its fused and you should be fine.
    When you buy a socket, get one with a flip down cover if your going for the glove. Don't want a set of keys or something dropping in and causing issues.
  6. Shane.
    Shane. Member
    486
    Yeah easy enough, as someone said just snag it on somewhere or take clean feed from the fuse box. I'm opting for 2 behind the dash and having phone charger coming out of one and then roadangel cable on the other
  7. Ash187
    7,496
    744
    Hmmm... 240v in the boot sounds good! and there i was thinking of buying a laptop charger for the car :p
    How would you set up a 240v in the car then? im guessing a power converter of some sort (as you can tell im not the greatest at electrics)
    very interested in this!
  8. Shane.
    Shane. Member
    486
    Yep, just need an in car inverter clean feed from fuse box is ideal
  9. Ash187
    7,496
    744
    hmmm... might have just found job to do over the weekend :sm4:
  10. ScottD3
    15,163
    1,123
    I'm thinking of doing the same thing but fitting USB ports.
    that way any thing can be charged up.
    I'm having issues finding a nice mountable USB A socket.
    All that is is a 300W inverter pluged in to a 12v live. you can pick them up from any car shop.
    300w is nice as it does not put a massive drain on the battery but you can't run much from it.
    I can run a laptop charger and a dremal.
    you need to check the Wattage of the item you're plugging in but also need to check out the start up wattage as well.
  11. Ash187
    7,496
    744
  12. Shane.
    Shane. Member
    486
    Best of both worlds ;)
    On a serious not possibly something like this would be ideal for what you want:
    Micro Auto USB Port In Car Universal Charger :: Buy USB Car Charger Here UK Stock
  13. nicksa3
    nicksa3 Member
    35
  14. ScottD3
    15,163
    1,123
    Could get this and take the internals out and make it/fit it where you want it go and be.
    Ash, Not sure but i've seen them for sale from Auto factors.
    Shane, Nice pic.
    thats what I got at the moment but I got the same thinking as Nick with cables every where.
    Nick, Thats cool. I'm looking for something a bit more subtle. Not sure why though, Its going in the glove box. lol
    That Universal 3A DC power Supply is a bit messy. Bin it. :)
  15. nicksa3
    nicksa3 Member
    35
    Someone with an, ahem, Skoda has had the same thought.
    Installing a USB charging port - BRISKODA.net - The Skoda Forum and Community
    My only problem with that is, a) finding a small USB adapter that can handle more than 1A and b)fitting it behind the glovebox.
    To resolve the second problem I think I might put it all into one of the shelves in my glovebox and fabricate a false front to it....
  16. Ash187
    7,496
    744
  17. Ash187
    7,496
    744
    Also if anyone is thinking of fitting something for the kids at the back you could use the small area underneath the rear ashtray. I honestly have no idea why i have a little cubby hole under the rear ashtray... i mean you can't fit anything in there!
    Audi do sell the socket... at £30!
    Audi 12v Socket - Stoke Audi Parts
  18. Boydie
    3,459
    597
    Anyone retrofit the socket to the boot?
    Do you need a new rear quarter cover?
    Part numbers?
  19. nicksa3
    nicksa3 Member
    35
    I've bitten the bullet and ordered the kit.
    I like the idea of putting a USB socket in the glove compartment best - everything runs off them these days after all. So I'm going to connect a new 12v socket, probably piggy backed onto the existing one. Then put in my Samsung Tab charger (produces enough current). From there I wil run a USB cable to behind the glove box where I will fit a USB socket:
    Neutrik - Data Connectors - USB - NAUSB-W
    with a cover:
    Neutrik - Audio - XLR Chassis Connector Accessories - SCDX
    That's the hardware taken care of. Now I just need to work out where to place the socket/charger combination (I'm hoping that there's room tucked underneath the centre console?), then running the usb cable without disturbing too much trim.
  20. Ash187
    7,496
    744
    not 100% but this part number looks promising:
    4B0 925 071 A/6PS
  21. Ash187
    7,496
    744
  22. nicksa3
    nicksa3 Member
    35
  23. Ash187
    7,496
    744
    Just spoke to docklands audi who say that the £30 socket is the rectangle one pictured in boydie's earlier post:
    They also do a smaller round socket with spring flap for £12.04 inc VAT.
    Had a look at the ebay ones and to be honest they all look cheap with a rubber flap. I Like the look of the OEM ones even if it is going to be hidden.
  24. ScottD3
    15,163
    1,123
    £12 for a OEM one with a spring flat is good price and I'd opt for that one over any cheap one off ebay.
  25. Ash187
    7,496
    744
    £5 something for the actual socket and then another £6 for the spring flap! even the Parts guys was like WOW what a jump in price for a damn socket! lol
  26. andi1
    andi1 WWW.APR-REMAPS.CO.UK
    220
  27. ScottD3
    15,163
    1,123
  28. Ash187
    7,496
    744
    For the price you may as well get the audi 1, similar look and it will look oem
  29. digon
    digon New Member
    Do you know what the part numbers are for these or what car they are fitted to. I've just been to my local dealer and they couldn't help. Would it be say a 2010 A3 centre console one from the non smoking pack?
    Dave.
  30. Ash187
    7,496
    744
    no the sockets are the ones used in the boot of our cars... there are 2 types/sizes depending if you have a 3 or 5 door A3.
    I think the 5 door version is the smaller one.
    I'll see if i can get the part number from you later on when i have my laptop.
