Installed RNS-E (Chrome) and have found the following...
DJAlix Apr 24, 2010
  1. DJAlix
    DJAlix VAG Car Coding Site Sponsor Team Ibis VAG Can Professional VCDS Map User Gold Supporter quattro ODIS (Offboard Diagnostic System)
    3,156
    2,567
    Hi there!
    Installed the 2009 RNS-E from my previous A3 Cab in to my new one, moved the bose pin and coded as 0209717, coded BT as 0011222 and added 37 under Long Coding in CAN.
    This car has FBMFSW, BT prep only (no armrest cradle or baseplate) and factory iPod in the Glove.
    All seems to work fine but VCDS throws out the following:
    16-Steering wheel -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    37-Navigation -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    The "Antenna Amplifier" error's I am aware of, nothing we can do about this short of changing out the bits, but was wondering if anyone might be able to supply any help re the other error's?
    Here is a full copy / paste of the log:
    Saturday,24,April,2010,15:10:03:33850
    VCDS Version: Release 908.2
    Data version: 20100326
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 10 15 16 17 19 25 26 37 42 44 46 52 55 56 61
    62 72 77
    VIN: TRUZZZ8P7A1005958 Mileage: 610km/379miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    26-Auto Roof -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (CDA) Labels: None
    Part No SW: 8P7 907 115 K HW: 8P0 907 115 Q
    Component: 1.8l R4/4V TFSI 0020
    Revision: AAH11--- Serial number: AUX7Z0IDFN70JE
    Coding: 015B000C24070160
    Shop #: WSC 01236 785 00200
    No fault code found.
    Readiness: 0110 0101
    Address 02: Auto Trans Labels: 0AM-300-04x.lbl
    Part No SW: 0AM 300 048 M HW: 0AM 927 769 D
    Component: GSG DSG AG7 402 1808
    Revision: 00040024 Serial number: 00000911270167
    Coding: 0000020
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
    Component: ESP MK60EC1 H30 0107
    Revision: 00H30001
    Coding: 13424012092200FFC81402E990210081390800
    Shop #: WSC 01236 758 00200
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 BL HW: 8P0 820 043 BL
    Component: KlimavollautomatH09 0140
    Revision: 000274 Serial number: 8P0820043BL
    Shop #: WSC 00000 000 00000
    Address 09: Cent. Elect. (J519) Labels: None
    Part No SW: 8P0 907 063 A HW: 8P0 907 063 A
    Component: BCM PQ35 M 105 0575
    Revision: 00105 AK
    Coding: 0E000A0FB205F140207060E00000094C531E5EAA3000D929E4000E040055
    Part No SW: 8P2 955 119 F HW: 8P2 955 119 F
    Component: Wischer AU350 H10 0040
    Coding: 00DD13
    Part No: 8P7 951 177
    Component: DWA-Sensor H0 H03 0040
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Address 10: Park/Steer Assist (J446) Labels: 8P0-919-475-7X1.clb
    Part No SW: 8P0 919 475 G HW: 8P0 919 475
    Component: PARKHILFE 4K H06 0120
    Revision: 11001001 Serial number: 93640933902785
    Coding: 000103
    Address 15: Airbags Labels: None
    Part No SW: 8P7 959 655 HW: 8P7 959 655
    Component: SR Airbag 9.43 H01 0020
    Revision: 93H01002 Serial number: 003BS000V3ZP
    Coding: 0021330
    Address 16: Steering wheel Labels: 8P0-953-549.lbl
    Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
    Component: J0527 H37 0070
    Coding: 0013141
    Part No: XXXXXXXXXXX
    Component: E0221 H06 0030
    1 Fault Found:
    01304 - Radio
    004 - No Signal/Communication - Intermittent
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
    Part No SW: 8P0 920 982 M HW: 8P0 920 982 M
    Component: KOMBIINSTR. VDO H03 0990
    Revision: D0H03005 Serial number: 224DI005005868
    Coding: 0000404
    Shop #: WSC 00726 210 88151
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 AF HW: 1K0 907 951
    Component: J533 Gateway H17 0231
    Revision: H17 Serial number: 1321J09C0800A9
    Coding: EDA17F26400602049101
    1 Fault Found:
    00463 - Control Module for Digital Sound Package (J525)
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 67
    Mileage: 614 km
    Time Indication: 0
    Date: 2010.04.24
    Time: 14:38:13
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Revision: D0H03005 Serial number: AUX7Z0IDFN70JE
    Address 26: Auto Roof Labels: Redir Fail!
    Part No: 8P7 959 255
    Component: VSG AUDI A3 H15 0110
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 192 S HW: 8P0 035 192 S
    Component: RNS-E HIGH EU H77 0650
    Revision: 04S Serial number: AUZBZ7H4130864
    Coding: 0209717
    Shop #: WSC 00860 210 82057
    5 Faults Found:
    00862 - Antenna for GPS Navigation (R50/R52)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 67
    Mileage: 614 km
    Time Indication: 0
    Date: 2010.04.24
    Time: 14:19:30
    Freeze Frame:
    Mileage: 655350 km
    Count: 65535
    Clock: 255:255
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 27
    Mileage: 614 km
    Time Indication: 0
    Date: 2010.04.24
    Time: 13:59:55
    Freeze Frame:
    Mileage: 610 km
    Count: 2404
    Clock: 13:59
    00878 - Connection to Speaker Front Left
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01111011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 27
    Mileage: 614 km
    Time Indication: 0
    Date: 2010.04.24
    Time: 13:59:47
    00879 - Connection to Speaker Front Right
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 27
    Mileage: 614 km
    Time Indication: 0
    Date: 2010.04.24
    Time: 13:59:47
    02005 - Coding Pin
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 67
    Mileage: 614 km
    Time Indication: 0
    Date: 2010.04.24
    Time: 13:59:54
    Address 42: Door Elect, Driver Labels: None
    Part No SW: 8P7 959 801 E HW: 8P7 959 801 E
    Component: Tuer-SG H04 0100
    Coding: 0000692
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K0 909 144 J
    Component: EPS_ZFLS Kl. 233 3001
    Revision: 00H17000
    Address 52: Door Elect, Pass. Labels: None
    Part No SW: 8P7 959 802 E HW: 8P7 959 802 E
    Coding: 0000692
    Address 55: Xenon Range Labels: 8P0-907-357.lbl
    Part No: 8P3 907 357
    Component: Dynamische LWR H01 0010
    Revision: 00000001 Serial number:
    Coding: 0000013
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0209717
    5 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 67
    Mileage: 614 km
    Time Indication: 0
    Date: 2010.04.24
    Time: 14:19:30
    Freeze Frame:
    Mileage: 655350 km
    Count: 65535
    Clock: 255:255
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 27
    Mileage: 614 km
    Time Indication: 0
    Date: 2010.04.24
    Time: 13:59:55
    Freeze Frame:
    Mileage: 610 km
    Count: 2404
    Clock: 13:59
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 27
    Mileage: 614 km
    Time Indication: 0
    Date: 2010.04.24
    Time: 13:59:47
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 27
    Mileage: 614 km
    Time Indication: 0
    Date: 2010.04.24
    Time: 13:59:47
    02005 - Coding Pin
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 67
    Mileage: 614 km
    Time Indication: 0
    Date: 2010.04.24
    Time: 13:59:54
    Address 61: Battery Regul. (J840) Labels: None
    Part No SW: 1K0 907 534 HW: 1K0 907 951
    Component: Batt.regelung H17 0231
    Revision: -------- Serial number: 1321J09C0800A9
    Coding: 0302085A
    Part No SW: 1K0 915 181 C HW: 1K0 915 181 A
    Component: J367-BDM H07 0125
    Address 62: Door, Rear Left Labels: None
    Part No SW: 8P7 959 811 B HW: 8P7 959 811 B
    Component: Tuer-SG H01 0050
    Coding: 0000144
    Shop #: WSC 01236 785 1012552
    Address 72: Door, Rear Right Labels: None
    Part No SW: 8P7 959 812 B HW: 8P7 959 812 B
    Coding: 0000144
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P0 862 335 AA HW: 8P0 862 335 S
    Component: FSE_256x BT H38 0600
    Revision: 00000000 Serial number: 00000005154378
    Coding: 0011222
    End ---------------------------------------------------------------------
  2. NHN
    29,577
    1,779
    Remove all the no fault found modules & just show us the faulting modules please as the rest are irrelevant.
    Assuming you have cleared the errors after install then rescanned as there will be errors showing until you have finished you're install, so if not already done, clear then post the errors only.
  3. DJAlix
    3,156
    2,567
    Hey NHN! Thanks for the reply :)
    I cleared all the errors before heading out last night. Will give it a scan in a little bit to see whats popped back up, filter the faults and post back up here.
  4. NHN
    29,577
    1,779
    Please filter your existing post aswell as most is not needed.
  5. DJAlix
    3,156
    2,567
    Well I had another play today and it turns out that I had activated voice control in one module but not in another, hence the steering wheel and CAN faults. A tick in a box sorted that, cannot remember the module, and enabled the speech button on my FBMFSW (for phone control only).
    The other faults never came back after clearing and driving the car around for a bit, other than the "00858 - Connection; Radio ZF Output to Antenna Amplifier 007 - Short to Ground" which is the norm from what I have been reading.
    NHH thanks for taking the time to reply, is much appreciated!
  6. NHN
    29,577
    1,779
    Yes the antenna issue will be apparent given you probably had a radio with an rns-e incompatible antenna system in previous, only fix is amp & cable changes, some are content as is.
  7. s8craig
    1,754
    56
    Your phone module was coded 0011222 and it should have been coded 0011422 for an RNS-E installtion.
    Also, if you moved the 3 wires from the blue 12 pin connector for the AUX to the 32 pin connector then your RNS-E could have been coded 0209757 to enable the AUX inputs. You must have removed at least one of the 3 wires to put the BOSE wire in to pin 7 of the blue connector.
  8. DJAlix
    3,156
    2,567
    Am on the lookout for a 2010 RNS-E so have only installed the 2009 one until then. Will go down the amp & cable changes route when I manage to grab one, but when I had the current unit in my last car I did not really have too many issues with reception.
    s8craig,
    Will there be any issues with leaving the phone module coded 0011222? I only borrowed the VCDS lead and will not have access to it again until next weekend. Well I guess the question is whats the difference between 0011222 and 0011422? Have not tested it fully but it all seems to work as is...
    I only relocated the Bose wire as I never use the Aux. Had to remove the grey wire from location 7 to make space for it, and taped it off. Will leaving the other 2 wires in place give me any issues?
    Thanks for your help and time guys!
  9. DJAlix
    3,156
    2,567
    Grabbed my mates cable again and coded up as advised with no error's thrown back at me, bar the Radio ZF Output to Antenna. Next job to be done I guess.
    I have a further question tho. I do not seem to be able to access module's 09 or 46. Have tired with the latest release of VCDS and the latest beta. Any idea's as to why this might be?
    Once again, many many thanks for all the help!
  10. NHN
    29,577
    1,779
    If its the new MY10 then the 09 & 46 have combined into a new 09 module, are you not able to log directly into the module 09 at all?
    So you've tried the 10.3?
    Also as already asked, please when posting your car vcds scan logs remove the NO FAULT FOUND modules so we dont have to scroll to Australia to get to the last post or relevant data. :p
  11. DJAlix
    3,156
    2,567
    Sorry NHN, am kinda new to this :sorry:
    Just completed another scan after trying to access the two modules, both via selecting 09 and 46 via the main screen and direct entry, no dice.
    Here is the edited scan:
    Sunday,02,May,2010,13:12:47:33850
    VCDS Version: Beta 10.3.0
    Data version: 20100324
    09-Cent. Elect. -- Status: OK 0000 (guessed that you might want to see this)
    37-Navigation -- Status: Malfunction 0010 (expected to see due to ariel current system)
    46-Central Conv. -- Status: OK 0000 (guessed that you might want to see this)
    56-Radio -- Status: Malfunction 0010 (expected to see due to current ariel system)
    Cannot be reached
    Address 46: Central Conv.
    Cannot be reached
    Thanks again in advance!
