Installation help??
thehogester Aug 22, 2013
  1. thehogester
    thehogester Member
    60
    I'm very confused by the sheer amount of cables I'm staring at here. Are any of you guys good at installing stereos?
    Thanks in advance!
  2. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,137
    what would you like to know ?
  3. thehogester
    thehogester Member
    60
    Well where do I start. Firstly I'm slightly concerned all these cables aren't going to fit in?
    The connectors i can pretty much work out, although I'm sure there was one I couldn't fit in the adaptor. I'll take more photos next time, I'm just asking from memory now.
    The bullet tip connectors, is it as simple as connect the same colours?
    I've got a boosted aerial adaptor which has a blue cable with it, does that need to go somewhere? I noticed there's a blue wire on the cables without a tip, this related to it?
    Sorry if I'm being vague, as I say next time I'll take more photos. For some reason I thought this would be a fairly easy job, but it's really bamboozled me lol
    Thanks again for any help!
  4. dualmono21
    1,137
    as regards the wiring id advise trying to tidy it up as much as possible and if possible wrap the wiring in either cloth tape or something similar
    with large amounts of wiring it can move and knock when you go over bumps in the road
    the yellow and red leads you have are live feeds one is ignition fed the other is permanent live
    im struggling to see the rest ... really could use some nice clear photos
  5. thehogester
    thehogester Member
    60
    Ok here's a few pics of the wires I'm dealing with. Now I think on my last attempt I had the connectors in the right place, it's more a case of getting the bullet connectors in the right place and figuring out where the blue wire off the aerial booster goes.
    Here's some more pics, and quick tips would be great. I'm going to have another go and putti h it all together today.
    ImageUploadedByTapatalk1377340279.550532.jpg ImageUploadedByTapatalk1377340287.973436.jpg ImageUploadedByTapatalk1377340297.397328.jpg
    PS. sorry if the photos aren't great quality, they're the best tapatalk will let me upload?
  6. thehogester
    thehogester Member
    60
    I'm now getting power but no sound? Really confused!
  7. thehogester
    thehogester Member
    60
    The loose amp on cable from the HU, held to the amp on connector on the adaptor gets a signal. However it sounds like garbage, any idea where I'm going wrong? I've almost got it!
  8. dualmono21
    1,137
    im sorry i simply cannot see enough detail in the pictures to tell you what should go where
    what colour cable are you using from the headunit to power the aerial adaptor ...
  9. thehogester
    thehogester Member
    60
    Thanks for the reply, I've actually now manage to get it all installed.
    What I struggled with was the blue wires to the amp. Once I figured a bit of soldering was needed, all became clear.
    Thanks for the replies!
