Inspection Service & Cambelt
pav-g Aug 8, 2007
  1. pav-g
    pav-g Member
    734
    Hi guys as the title says, cars booked in on tuesday at a local audi specialist. Its the 70k annual inspection and before anyone asks £90 plus VAT for the service and £310 plus vat for the timing belt etc.
    Question is whilst cars in is there anything else I could have done or looked at...
    pav
  2. Macduff
    Macduff Member
    742
    Brake fluid change?
    Are they doing the water pump? If it's not required then when was the coolant last changed?
  3. golf
    golf ***** rent boy VCDS Map User
    1,556
    I'd ALWAYS recommend changing the water pump if the cambelt is being changed. The existing water pump will come out when the new belt is fitted anyway, so you might as well change the pump if you're not planning to.
    Also, wouldn't it be cheaper to source the parts yourself and that way you only have to pay for labour?
  4. pav-g
    pav-g Member
    734
    Thanks for the advise. Brake fluid got changed last year so Ok and yes will be getting water pump changed with cambelt etc. Re sourcing own parts Ive no idea what to be looking out for so I suppose let Chris sort it all out.
  5. doogleman
    doogleman Member
    95
    Id agree with golf to replace the pump anyway.
  6. golf
    1,556
    You'll save a fortune if you get your own parts. Try GermanSwedish (www.gsfcarparts.com). You're in Bradford aren't you? They've got a store there, and you'll be able to get your parts from there direct.
    Water pump and cambelt cost me £44 for my Golf, same 1.8T engine. Just paid £90 labour on top.
  7. doogleman
    doogleman Member
    95
    Now that we are on topic, I am almost due a timing belt change. What are the part numbers for a 2001 A4(B6) 1.9TDI for the following?:
    - Timing Belt
    - Timing Belt Tensioner
    - Water Pump
    Thanks in advance, :icon_thumright:
  8. pav-g
    pav-g Member
    734
    Thanks mate for that, I didnt realise prices were so darn cheap and yes we do have a germanswedish car parts in bfd, will pop over tmrw.
    Can someone advise me exactly what I need, please feel free to add to list..
    1. Cambelt
    2. Water Pump
