Inlet removal problems
tdia4 May 30, 2011
  1. tdia4
    tdia4 TDIPOWARRR
    613
    Wanting to remove my Inlet manifold to clean it out, 5 out of the 6 Hex headed bolts will come out perfect but on one of them the head is completely threaded and it is practically a circle instead of a Hex shape, so whats the best way of getting this ****** out?
  2. tonya4
    tonya4 TDi Powerrrr
    408
    try hammering in a larger hex or spline bit,and then undo the bolt
    hth
    tony
  3. tdia4
    tdia4 TDIPOWARRR
    613
    Cheers, will give it ago but not sure one will go in.
  4. Keyser Soze
    Keyser Soze Member
    78
    How's your drilling? Can you get a drill bit to it?
  5. tdia4
    tdia4 TDIPOWARRR
    613
    It's all pretty tight in that area so not sure if I would want to go drilling really, found some bolt remover things on ebay but there are so many different types so not sure which ones I need.
  6. tonya4
    tonya4 TDi Powerrrr
    408
    if it's a bolt type head,try hammering on a slightly smaller socket,then undo,or as you have said,try a bolt extractor.
    tony
  7. tdia4
    tdia4 TDIPOWARRR
    613
  8. abblettm
    abblettm New Member
    15
    Best bet is to get a spine into it, if a 12 point socket over the top of it, try to heat it up if poss
  9. mike-a
    mike-a Member
    103
    Big hammer,imperial allen key just bigger than socket and give it's good wack.
  10. tdia4
    tdia4 TDIPOWARRR
    613
    Cheers for all the suggestions guys, tried banging in a imperial allen key but with no luck, get it in pretty far and it seems to be held pretty tight but as soon as I try to undo the bolt it just spins out.
  11. aragorn
    18,600
    870
    torx or spline can sometimes work better as they "dig in" rather than just sort of smushing into the hole.
    Can you get a welder into it? if you can you could weld a bolt into the hole.
  12. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,776
    33
    Irwin Bolt Grips. Fecking awesome things!
  13. tdia4
    tdia4 TDIPOWARRR
    613
    Bit tight for a welder really, I'll try Torx bit next time I try get it off, think my dad may have some splines as well so when i'm next at the parents i'll give it a go.
  14. bmarshall
    bmarshall Member
    Try cut a straight grove with hacksaw blade to fit a big flat screwdriver head into it?
  15. bmarshall
    bmarshall Member
    Or just cut the head off and replace bolt after
