Injector removal
Sock Mar 24, 2011
  1. Sock
    Sock Shark in a Goldfishes clothing
    576
    Can anyone give me a quick how too on removing the injectors from my a3 2.0l tdi 170?
    I've only had a glance but couldn't see them so starting from where they are and any tips on removal would be great?:wacko:
  2. devonmikeyboy
    devonmikeyboy As far from JBS as possible !
    1,245
    Same as you would with a BKD PD140.
    Remove rocker cover.
    Remove rocker
    Remove cams
    Un-clip the injectors from the wiring harness
    Either side of the injector is a torque bolt. Remove the bolts then prise the injector out.
  3. Sock
    576
    Wtf lol?
    You have to remove half the engine to get to the injectors?
  4. Lewis583
    956
    91
    Yup, glow plugs are right next to them aswell lol
  5. Sock
    576
    Lol so I assume that means resetting the timing belt and everything after?
    I wonder if an injector fails under warranty , audi will change all 4 due to the size of the job? Lol
