Injector Recall for PD170 - Might be already known to you lot.
drnutta Dec 5, 2011
  1. drnutta
    drnutta Member
    372
    Hi Guys,
    My car was in Audi today for its MOT.
    While it was being booked in a recall notice appeared stating that my car has been flagged up to get all injectors replaced FOC.
    Apparently the Recall notice was only issued today? (Saw it pop up on screen with date of today)
    I thought I would just let you guys know.
    Alisdair
  2. Ash187
    7,496
    744
  3. Agent_Trig
    Agent_Trig Member
    552
    Is this just for 2006 170 and not the 140?
  4. A1DEYB
    A1DEYB Well-Known Member
    1,681
    43
    ^^ 140 models made in 2006 can be affected too, mine was checked by Audi Leeds FOC.
  5. Ash187
    7,496
    744
    checked or changed?
  6. A1DEYB
    1,681
    43
    Checked mate, i phoned up Audi UK, spoke to a chap called Dominic and asked about this issue, he told me that my MY A3 140 was affected and told me to get my car booked into Audi Leeds.
    Audi Leeds checked the part numbers and ran a diagnostics check on them and they came back with a clean bill of health.
    The bloke on the service desk at Audi Leeds told me that the 140s can suffer from this 'dodgy batch' of injectors but it's much more common to the 170 variant.
  7. N8
    17,163
    718
    Mine is a 140 (08) plate is it worth ringing Audi UK?
  8. Red-Eye
    Red-Eye Member
    50
    Had my car die on me this morning :-(
    Got towed to Audi dealer, as soon as I got there they said there is a recall on this car due to injector problems.
    I asked when this was issued country wide & they said Friday ;-)
    All repaired foc except for a large bill for a holed inlet manifold :-(
    Glad it went now before the bad weather kicked in, nice to see Audi are taking note, regained my confidence with them :)
  9. paultaylor
    paultaylor Member
    294
    Was the hole in the inlet connected to the injector failure?
  10. drnutta
    drnutta Member
    372
    Well my car is a Jan 2008 170 so unsure if this is only for 170... i saw on screen 140-170... cant confirm though.
    Glad the info helps.
  11. Red-Eye
    Red-Eye Member
    50
    No don't think it was, has been leaking a little oil next to the vacum unit (above alternator) for approx 8 months now, not been a major issue so not realy bothered with it, till now !!
  12. Smithymartyn
    Smithymartyn Member
    34
    Spoke to Leicester Audi. They will have car in (06 170 Quattro) and check injectors and run diagnostic FOC. Will replace if anything deemed faulty. However, if other faults are flagged by the diagnostic they will charge the £132 + VAT (unreal)!!
    I have a dilemma as sporadically my glow plug light has come on (PL12600 - Inlet Manifold, which has been checked and deemed OK by an independent), so this will no doubt flag again prompting a charge.
    Does anyone know what the likely symptoms are of faulty injectors? Could it be linked to the fault above and I have also noticed a hesitation when accelerating when the car is between 3-4k RPM.
    Any help on the back of this post would be helpful and may save me a few quid!!!
    Cheers:think:
  13. jrsteeve
    jrsteeve Member
    136
    So is this now on 2008 models too?
  14. N8
    17,163
    718
    I've also got hesitation :wub:
  15. MOOSH
    MOOSH Member
    253
    Well mate i had the same as you, i got an audi tech friend to check mine and he came back to me saying its the manifold intake control flap, same thing my vag com said so i said no chance it is the injectors and he said basically computer says no.
    So my car died yesterday on a roundabout, my hazards light worked and then didnt work, no brake lghts its was choas!
    So i had the manifold intake control flap fitted today and the car still wont start.
    So god knows what next, my car is at the volvo garage as my friend towed it there as he works there so i am going to scan it in the morning and hopfully it comes up with something if not a call to audi techincal guys.
  16. drnutta
    drnutta Member
    372
    Hold on guys... i thought a recall means regardless if your car is working at the moment... Audi will have to replace the injectors regardless...
    Wont just checking them mean the recall has not been carried out... or just a failure waiting to happen?
    I mean my car has been perfect... but they are replacing all of the injectors...
  17. Ash187
    7,496
    744
    very good point! last time i enquired about it they had told me i had to pay £150 for a diagnosis! i'm going to contact them again and ask them about the recall and see if i qualify for it.
  18. Red-Eye
    Red-Eye Member
    50
    Just a heads up, got my car back today with the injectors fitted foc ;-)
    The service guy said that if it hadn't broke down on Monday, I still would have been contacted to get the fault fixed !!
    Hope this helps, if not get to your dealer ASAP to check or get them fitted.
    Can be dangerous if it happens on the motorway :-(
  19. cloughy
    cloughy Member
    515
    Can't find the recall notice on the Vosa website???
  20. fangio
    fangio Well-Known Member
    1,507
    180
  21. Ash187
    7,496
    744
    very interesting read! alot of ammo there to take to audi if they try to dismiss you on the fact of not buying the car from them directly or having FASH! its annoying that
    IMO Audi should be sorting these issues out for customers without the need of the customer complaining. they should be on the ball about it and do whats needed to fix the issues.
    I will be contacting Audi again very soon to have my car checked of injector issues.
  22. S3 Dave
    S3 Dave Now running on Heavy Oil
    432
    Right then after reading a lot here and driving my oil burner for 6 months 2007 170 PD S-Line I thought it time to pick up the phone....... I started with the supplying dealer who confirmed it had had 1 injector was replaced during the 3yr warranty period but not all 4 had been replaced. They also pointed out it was on a "field service" (recall) to have all 4 replaced. So I called my local dealer Stratford Audi who after deleting my old car managed to sort out the system and agreed the injectors are on a recall RK-2 somthing or other. I asked does it qualify for a courtesy car he said yes so all booked in and he said it'll get a visual inspection and a wash and vacuum!
    Now on a 5 yr old motor that ain't half bad! Bet they'll try and find £500 quid's worth of faults but hey ho.
    SO if you have a 170 2.0l TDI PD PHONE YOUR LOCAL DEALER NOW!!! FOC is FOC!!!
  23. SWILKO
    SWILKO Member
    105
    Very useful thread guys. I phoned Audi today and my 2007 170 Quattro S Line has been identified as a potential candidate. Booked in for next week but I forgot to ask if this check is FOC, it better be!!!
    S
  24. PhilM81
    PhilM81 Quattro, bring on the SNOW!
    84
    Car died last night! on a dual carriageway ~60mph in 6th, lost power, no revs, loads of lights!
    Police had to divert traffic and AA towed to Audi dealer, gutted to say the least. I was that pleb on the side of the road causing traffic jams!
    Car was already booked in with the same dealer for a new turbo today (good will on parts, I pay labour).
    Audi are now replacing all four injectors FOC + Turbo, apparently everyone is getting a letter in the next two weeks about the recall for injector replacement.
    Hopefully it will be right as rain by the end of the day!
    Can anything else go wrong??! on a 57 plate 2.0 TDI 170 quattro??! DPF, Clutch.... fingers crossed.
  25. grantDUBshaw
    grantDUBshaw Active Member
    240
    62
    Just rang Audi and i got to book my car in next week for injectors to be checked! just gotta find a day im free now :/
  26. Ash187
    7,496
    744
    Do all you guys have 170s or are some 140s getting this done as well?
    are you just going direct to the dealers or contacting Audi UK?
  27. rsb2486
    rsb2486 New Member
    26
    Rang my local Stealer (Lister Coventry) and cars booked in to get all injectors changed FOC!
    .. if youve got a 170pd then ring your local dealer and see if your car is listed as being in the injector recall!
  28. SWILKO
    SWILKO Member
    105
    Itwasntme,
    I got a 2007 170 and phoned Audi head office. They told me to get it checked at local dealer..
  29. S3 Dave
    432
    Contact your Dealer!!
  30. S3 Dave
    432
    Checked! Replaced is the only fix! The recall is to replace don't stand for that!
  31. rsb2486
    rsb2486 New Member
    26
    Yup!! as above.. get them replaced NOT CHECKED!
  32. fangio
    1,507
    180
  33. paultaylor
    paultaylor Member
    294
    I emailed Audi South Dublin Service to see if the recall was for outside the UK(Audi UK had kindly agreed to replace all four injectors and loom FOC in Belfast a month ago)
    They came back and said that they received the recall notice on the 5th of December and can do all the work FOC with a replacement car provided next wednesday.
    Good service all round
  34. drnutta
    drnutta Member
    372
    Hi Guy, Gals,
    Just a quick update got the injectors replaced FOC.
    I am actually amazed that i can actually feel a difference... now considering there was actually nothing wrong that I can tell on my car before it went in... the car seems to be ALOT smoother.
    For those interested... the new parts seem to be bosch made.
  35. rsb2486
    rsb2486 New Member
    26
    im in the same boat.. got mine booked in for nxt monday to get them replaced, even though ive not had any issue's with the injectors.
    when you say you can notice the car to be smoother.. i take it acceleration, idle etc..??
  36. grantDUBshaw
    240
    62
    Got a phonecall of audi halesowen today saying my car was ready to be picked up 170pd sportback, brand new injectors and loom FOC :) vwry happy :) any noticed a difference from the change yet??
  37. S3 Dave
    432
    I'll let you know 2mrw get mine back then.
  38. jrsteeve
    jrsteeve Member
    136
    Mine's being 'inspected' next Wednesday so looks like it could be the 2008's too.
  39. SWILKO
    SWILKO Member
    105
    Handed mine into Edinburgh Audi today. Garage job sheet says "THIS IS NOT A RECALL-THIS IS A WORKSHOP CHECK"
    Total joke, will let you know how I get on guys......
    PS
    Mine has been remapped so they better not tinker with the ECU!
  40. jrsteeve
    jrsteeve Member
    136
    Same as mine, apparently they shouldn't touch the map even if they update the ecu as it takes some doing. I just emailed Audi customer service and asked if mine was on the recall list, got a phone call a couple of days later (today) to have it inspected. Will see what happens.
