Injector Leak !
TwistedMind Apr 3, 2011
  1. TwistedMind
    TwistedMind Long Live The A6
    115
    Morning all
    I have deisel leaking from the top of one injector. Can the seals be replaced?
    Dont fancy forking out for a new one !
  2. adamss24
    adamss24 Well-Known Member
    4,549
    392
    Wich seals do you mean, the tiny copper seals between the leak-off pipe's niple or the union ? The copper seals are available at the dealer about 75p each...
  3. Gavin0478
    Gavin0478 Active Member Team Daytona Team V8 VCDS Map User quattro Audi Q7 TDi
    518
    37
    if its a copper washer, heat it with a blow lamp till glowing red hot then dunk into cold water.
    iirc its called quenching and it softens the washer back up so it seals
  4. TwistedMind
    115
    Talking in my stupid terms, it seems to be leaking from the joint from the pipe nut to the top of the injector.
    Does that make it any clearer ?????????
    Sorry !
  5. TwistedMind
    115
    Have to get this sorted, noticed this morning deisel pooling on the engine !!!!!!!!!!!!!!!!!!!!!!
    :wtf:
  6. TwistedMind
    115
    Anybody know of a liquid gaskit thats not effected by diesel ?
  7. adamss24
    4,549
    392
    Use a 17mm spanner and tighen the union nut mate, it should stop the leak. If it does not then you will need a new set of pipes as they are not available separate ! I might have a spare one ine me van somewhere if you need one...
    TwistedMind likes this.
  8. TwistedMind
    115
    Adamss
    Great, Got the spanner on it...... hit it a few times with the hammer to tighten up. Worked a treat !!!!
    Thats one leak sorted. But i have noticed a very small leak at the bottom of No2 injector. Would this just be a replacment of the "O" ring ??
    Are they easy to remove ??
    Thanks for the help !!!!!!!!!!
    :o.k:
