Injector issues
Biggles44 Nov 27, 2013
  1. Biggles44
    Biggles44 Member
    60
    Yet more problems with my pile of shyt.
    After having a new head and all the other stuff done after our cam belt going, the garage tells me we need new injectors at £300 a pop.
    Do the injectors get damaged when a cam belt goes on audi. The car is a a3 2007 2.0 tdi 170 bhp.
    this is the worst car I have ever owned and when it's fixed will be glad to see the back of it.
  2. phil_w
    phil_w Active Member VCDS Map User Team Brill Red Audi A4 Audi Avant Owner Group S-line owners group
    606
    58
    170 engines are covered under an injector recall. Audi will process the claim if you take it to them....
  3. Biggles44
    Biggles44 Member
    60
    Injectors have already been done on a recall. My question is, do the injectors get damaged when the came belt goes ?
  4. phil_w
    606
    58
    Apologies fella - didn't realise.
    No idea on the amount of damage that can occur - sorry.
  5. Biggles44
    Biggles44 Member
    60
    That's ok, thanks anyway mate ;-)
  6. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    if there not set up rite when putting the head on if there like the 140 injectors then yes they can broke when setting them up
  7. Biggles44
    Biggles44 Member
    60
    Thanks for the reply.
    So who would be at fault regarding the injectors ?
  8. tdi-man
    1,783
    64
    not sure if the 170 inj get damaged when cam belt goes. you need to ask why they need replacing ?
  9. Ash187
    7,518
    750
    Injectors on eBay go for about £80
  10. Biggles44
    Biggles44 Member
    60
    The problems continue. After cam belt going 3 weeks ago, had recon head fitted,new cam kit and all the other jazz. Got the car back, and when driving it's fine until you put your foot down and it starts missing. So back the the garage, and they said injector number 2 needed replacing, so they replaced that and the car was still missing, so they replaced the other three as they'd said it upset the balance. Continued missing, then they told me they were given the wrong injectors. So they replace injector 2 again with the right injector, and it's still the same. So I rang audi and they said the garage have no idea what there doing, so I'm going to collect the car from the garage tomorrow and take it to audi to see if they can source the problem.
    what a friggin joke this is turning out to be.
    car drove perfect until cam belt going, now it's all messed up.
    any one have any ideas what it could be ??
  11. Biggles44
    Biggles44 Member
    60
    Anyone ?
  12. tdi-man
    1,783
    64
    where abouts r u
  13. tdi-man
    1,783
    64
  14. Biggles44
    Biggles44 Member
    60
    Yeovil, Somerset. Not sure what to do about the garage that's worked on it, I haven't paid them yet as I'm sure they have created a problem. Taking to audi in the morning to get there opinion, hopefully
  15. tdi-man
    1,783
    64
    probs not set up correctly
  16. Granta
    Granta Active Member
    294
    62
    I'm sure if the oil used is not correct then that can damage them and with it missing when you put your foot down sounds like a compression issue around your valves/springs.
    I have seen it on a merc with a recon head after revving it up a couple of the valves would stick open. Turns out incorrect valve springs were used,
  17. Biggles44
    Biggles44 Member
    60
    Update.
    the garage that did the head and cam belt for me has now said they can't fix the above issues, so I have taken it away from them and taken it to audi, I have to now pay £200 for full diagnostic, they will then tell me what the issue is as nothing is showing up on audi computer.
    as I will have to pay audi to now fix it, would you pay the other garage any money for what they have done, as I now have a car that is pretty much un drivable
  18. hollows wife
    hollows wife Well-Known Member
    1,404
    164
    probably a valve not seating correctly
  19. Biggles44
    Biggles44 Member
    60
    Audi are saying they think from the test drive that it's a injector issue. But would you pay the previous garage for what they'd have done ? Bearing in mind I'm having to pay for it to be fixed and a car that will hopefully work :)
  20. hollows wife
    1,404
    164
    could be an injector issue ,even after a diagnostic if the injectors seem to be in spec ,unless they try a new set of injectors you'll still not know . audi won't try a new set unless you're paying for them first ,there not £300 each now there less than £200 each as so many have gone faulty.
    tbh audi only have as much chance as a good indy to correct the fault . probably even less as if guided fault finding doesn't come up with some answers then the techs there will be left scratching there heads.
  21. Biggles44
    Biggles44 Member
    60
    Friggin nightmare this car, running out of money to keep chucking at it. Since I've owned it, it's been of the road for nearly half the time.
    should of got a ford ;-(
  22. hollows wife
    1,404
    164
    lol @ ford , don't go there you've just gone to the wrong people to sort it . a good indy garage would rectify the fault ,obviously not bothered about there reputation.
  23. autolatry
    autolatry Active Member
    347
    67
    Any ideas as to how the injectors became damaged? Wtf is this they have to set up sh!t? Ive just slotted mine back where they came from with new seals on. Surely the ecu is still the same as before they were removed?
    Also you should pay the garage mate (providing they are just mechanics and they didn't sell you the car)
  24. hollows wife
    1,404
    164
    the injectors can be damaged and so can the bores where they sit , they have to be levelled when tightening bolts or it can damage the bore hole for the injector and the injector seal , also if the bolt for the rocker above the injector is tightened up too much ,it damages the internals of the injector .
    seen one only the other week in a caddy where the injector wasnt even tightened down properly ,damage was that bad the bore hole was left oval , cost of repair a new head .
    autolatry likes this.
  25. autolatry
    347
    67
    Oh I see. I thought by set up it meant they needed 'programming' in something.
    Mine are held in place by the fuel rail so I would hope I've put them in correctly.
  26. tdi-man
    1,783
    64
    if it was me I wouldn't pay um a penny . they didn't fix the problem.
    Biggles44 likes this.
  27. autolatry
    347
    67
  28. Hoesty
    Hoesty Active Member
    227
    Lol!
    You would think Audi would repair since it's been on recall already or cover most parts and labour costs with goodwill.
    Hope it all plans out.
  29. Artimus
    Artimus Shortback
    2,017
    485
    They've washed their hands of it so they shouldn't be getting a penny from you. In all truth, If it turns out it's their doing, you should be taking Audi's final invoice to them for reimbursement.
  30. Biggles44
    Biggles44 Member
    60
    New update.
    cars fixed :arco:
    The **** from the first garage messed up the injectors, used the stretch bolts twice or more, instead of once only, used the seals twice or more, some bolts were only done up just over hand tight,no bolts were torque tightened. Joker.
    so audi have fixed it at a cost of £436, there going to service the gearbox tomorrow for fixed price £149, feeling happy again and will be happy to get it back.
    :applaus: To Audi
  31. autolatry
    347
    67
    Good news mate. If that's the case then fair play, don't pay the first garage anything.
    You going to keep it now?
  32. Biggles44
    Biggles44 Member
    60
    It's our dream car to own, it's been off the road more than on, cost me a fortune to get fixed,but I love the look of it, and when it's on form it's the dogs nuts to drive.
    so I'm going to say yes I will keep it, and fingers crossed it won't let us down.
    autolatry and Artimus like this.
  33. Granta
    294
    62
    Good news. ! Glad it's sorted!
  34. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User quattro Audi A4 Audi Avant Owner Group TDi
    5,900
    2,703
    Glad you have the car sorted the place you took it too first sounds like a load of cowboys. Very shoddy work no wonder it wasn't running correctly.
    Karl.
