Induction To cone or not to cone ?
xxxxSMITHYxxxx Aug 15, 2013
  1. xxxxSMITHYxxxx
    xxxxSMITHYxxxx Member
    37
    Hi all,
    I have just got an a3 quattro and was woundering if it is better to stick on cone filter on it or just replace the pannel filter with a good k&N pannel.
    Does this car bennifit from a cone or not i know some cars do not like it and run worse
  2. Gizmo20VT
    Gizmo20VT Active Member
    294
    Hi SMithy
    There are several posts regarding cone filter, stock box, pro's and con's if any.
    Try use the search function and also browse over the stickes.
    Welcome to ASN
  3. xxxxSMITHYxxxx
    37
    Thanks for the welcome :)
  4. xxxxSMITHYxxxx
    37
    I have had a search on the forum, Can not seem to find any good information about induction on the a3,
  5. Vex182
    Vex182 Guess what I drive...
    1,035
    79
  6. Jay 01 s3
    Jay 01 s3 Member
    149
    S2000 prob the cheapest and most beneficial , but you will need a reducer if your car has a ko3/ ko3's
  7. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,188
    <tuffty/> likes this.
  8. xxxxSMITHYxxxx
    37
    Yea in that case i have all ready put a cone filter on it and a cold air feed to it so i will keep it like that,
    Unless anyone has a better idear open of offters if some one has found something that works better.
  9. xxxxSMITHYxxxx
    37
    The little tab/nipple thing that is on the bottom half of th orignal air box at the very end closest to the wing what is that?
  10. superkarl
    superkarl MAN OF STEEL
    9,623
    2,488
    just a mount that locates it on to the inside of the wing
  11. xxxxSMITHYxxxx
    37
    Ok kewl thanks just wanted to make sure i wasent leaving any pipes,breathers or sensors unpluged after fitting a cone filter
  12. fanta
    fanta Active Member
    253
    33
    What have you done with the cold air feed? I've noticed the car doesn't quite pull like it did now I've put this and the oversized tip on.
    Thinking about making a blanking plate out of metal, there's a good guide here on asn. But the cold air feed is what I think is lacking, before with the box it had direct connection to cold air, now it's got a mix of both...
  13. superkarl
    9,623
    2,488
    temp of the air pre turbo means naff all on charged cars.
    Larger tips tend to move the power curve to the right a bit, less lower down, more up top. With an up to date map taking into account the mod/s that wouldnt be the case.
    Should feel nice and free top end tho, 6k+
