Indicators playing up - relay?
The Doctor Jan 12, 2012
  1. The Doctor
    The Doctor Well-Known Member
    1,394
    189
    Hi chaps,
    For some time now my indicators have been a bit temperamental - sometimes they flash fine, other times they have been flashing erratically (that's erratically, not erotically). Anyway, this week I've noticed that they now actually stop working after about 5-6 flashes, even if the indicator stalk is still in the correct position. Turning them off and on again solves the problem for another 5-6 flashes.
    I think this may be the hazard relay - any thoughts/advice on this one? Anyone had the same problem?
  2. Nilz
    11,335
    881
    Hey Paul
    Hope you are well mate...
    It sounds much like the hazard relay that has gone, I did mine a while ago, cost about £30-40.
    It doesnt take much to replace either....
    You may need to remove your stereo and prise the whole hazard unit out, then just click the new one in place...job done :)
    Oh and I had the same symptoms as you.
  3. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,913
    165
    Good to see you again matey :)
    But Uh oh... Getting turned on by flashers lol...
    In all seriousness, It will either be the flasher relay or the stalk. Contacts in both can wear and cause issues like this.
  4. Rogue-24-84
    Rogue-24-84 Member
    268
    sounds exactly the same as a problem i had with my old 18t, was the hazard light switch.. got a new one from audi fitted it and never went wrong again, abit fidely as its actually attached to the back of the hazard light button itself, but it'l sort it bud 99.9% sure
  5. Broken Byzan
    13,237
    465
    Hazard switch for deff. It has 2 relays in it, one for hazards and one for indicators.
    It's why your hazards probably still work. iirc there is a later one than the std fitted unit and it's sub £40.
    Laterz
  6. george_seamons
    george_seamons Active Member
    314
    82
    I have one spare from my track car if its any use to you? From an X reg A3.
  7. The Doctor
    1,394
    189
    OK thanks chaps, that's what I suspected. I think I've seen a guide for the hazard relay replacement on here somewhere so will have a search, unless anyone has the link to that thread handy?
    Mark - yes the hazards are fine.
    I'll get myself a new one for that price, but thanks for the offer george_seamons.
  8. Martin82
    Martin82 Member
    71
    I had this as my indicators were intermittent sometimes and only one side of the hazards worked, replaced the hazard switch and all was well.
    Mines a pre facelift s3 but i did it like this:
    Drop ashtray (1 screw in the centre)
    Remove stereo
    Remove 2 screws from where stereo was
    pull facia out and drop out of the way just enough.
    Hand into where the stereo was, couple of fingers up into the gap behind the hazard switch and push with a bit of force and out it pops.
  9. jimmp
    jimmp Member
    194
    Crikey!
    I didn't have to remove the stereo! I just got off the faceplate over the ESP & cupholder and then it was accessible...
    You guys got aftermarket head-units, yeah?
  10. Snuff
    Snuff satan's driver
    87
    my indicators have just packed in too , i hope i dont have to remove the standard head unit. is there a how to guide on removal
  11. pioneer181
    pioneer181 Torque talks
    61
    This happened to me today as well. Wouldn't work at all. Then worked if I pushed the stalk a little harder than normal, but only indicated left regardless of which way I was trying to indicate. Thanks for everyones replies as I would of guessed it was the stalk.
  12. The Doctor
    1,394
    189
  13. neil.c
    neil.c Senior
    567
    Mine has just packed up too, it has been playing up on and off for a while, I wizzed it out before tea, a tap seemed to start it up every time it jammed. I have cleaned up the contacts and adjusted the common pole to be more central, it now seems to be working again so we shall see how it goes :)
  14. Gops
    3,198
    666
    Mine stopped flashing then I put the hazards on and it's worked ever since lol. If its not entirely broke then it's a gooden :)
  15. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,155
    1,987
    Ha !
    Yeah kid yourself it's not going to happen to your car,I did and guess what ? Two weeks later kaputt
  16. Nilz
    11,335
    881
    LOL!!!
    Gops, give it some time..my bet is on the way back from AITP tomorrow ;)
  17. Gops
    3,198
    666
    Lol well it's been ok for a month now. I know it'll happen soon, just hoping the car gods like me and keep it working till I can be bothered to get one. Dont jinx me nilz :(
  18. Nilz
    11,335
    881
    Sorry bro.xxx
    Im sure it will be fine :)
