Indicators not working properly
clcollins Aug 14, 2006
  1. clcollins
    clcollins Member
    278
    Hi all, wondering if any of you have had / or heard of a similar problem. My indicators seem to have died…………when I indicate they do one of three things, (1) nothing, (2) flash for about 2 seconds at three times the normal speed, or (3) flash once at normal speed.
    I’m hoping it’s just the flasher unit but have a feeling that it’s the indicator stalk. My reason for thinking this is that when I put the hazard lights on the lights work perfectly, so unless there are two flasher units (one for normal indication and one for hazards) then it’s the stalk.
    Anyone got any ideas / advice?
  2. cocain
    cocain RAA RAA like a dungeon dragon!
    214
    umm not sure but i remember when I changed my sub over in the back of my A3 a while back I had some strange things like that happen to my indicators. took it apart and went through the whole process again and it was ok. I asked someone and they said it may have been a dodgy earth wire in the loop but your case may be different.
  3. jojo
    28,856
    3,516
    Yes, a dodgy earth on the A3 makes the dash go funny in a spooky sort of way, indicators become intermittent and the dash lights flicker all over the place.
  4. MarcA3Turbo
    MarcA3Turbo Member
    Had a similar problem a while ago. Replaced the relay, but it didnt solve it, so have now put it down to the indicator stalk itself. Theres a replacement stalk on the way to me at the moment, so if you want I can let you know how I get on? And theres only 1 relay for both the hazards and the indicators. And I had the same symptoms too i.e hazards worked fine but indicators play up.
    HTH
    Marc
  5. clcollins
    clcollins Member
    278
    Marc have you changed your indicator stalk yet, if so has it sorted out the problem?
    As I have the same prob and really don't want to change the stalk without knowing for sure that's where the problem lies, how do I trace an earth fault (if there is one)?
  6. MarcA3Turbo
    MarcA3Turbo Member
    Hi,
    indicator stalk was posted yesterday, should have it tomorrow, but I'm away until next Wednesday, so won't have it on until at least then, sorry! I'll let you know though as soon as I get it on.
    Marc
  7. If your after a stalk I think I've got one around somewhere
  8. madvw
    madvw Active Member
    2,489
    have you replaced your stalk yet marc? did it fix it?
  9. MarcA3Turbo
    MarcA3Turbo Member
    No, believe it or not, still haven't gotten around to it! Have the new stalk sitting in my glove box, but haven't had it fitted yet. The problem is so intermittent i.e only happens for a few minutes every few weeks that it keeps slipping my mind. I'll make the effort to head down over the next couple of days though, just pure lazy really...
  10. MarcA3Turbo
    MarcA3Turbo Member
    Eventually got around to fitting the new stalk last week, and glad to report that the problem is completely cured! Happy days :)
  11. olekvi
    olekvi Member
    68
    I had a similar problem.
    Hazards worked 100%, but not indicators.
    A new relay fixed everything. It is very easy to change, so you should give it a go :)
  12. dan_a3
    dan_a3 Member
    196
    I have got the same problem with mine, Spoke to Audi and they said it is a common fault and 9 out of 10 times is the hazard light switch blocking the signal of the indicators. Havent brought or fitted anything yet though so would be intersted to hear how you get on.
  13. bthechronic
    bthechronic jack
    audi a3 quattro 1.8 turbo ,,,will you please tell me how you get on clcollins as i have the same problem by the sounds of things ,,,and can any one tell me how much the indicator stalks are,, do i need to change the relay as well all info greatley accepted
  14. MartayMcFly
    MartayMcFly Booooooost VCDS Map User Gold Supporter
    2,751
    353
    Mine was doing this when I test drove it before I bought it and one of the mechanics at the shop said the hazard relay was a common problem. They swapped the whole hazard switch bit out from an A4 and I haven't had a problem since.
  15. ty160
    ty160 s3 tys
    87
    this happened on my s3 and was the relay just replaced it , it just plug in
  16. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,142
    1,971
    that was two and a half years ago so hes probably had another relay since then :)
  17. leshkin
    leshkin Hold my beer... VCDS Map User Gold Supporter Team Sepang Audi S3
    2,500
    1,420
    Probably a new car :laugh:
  18. adz_rolls
    adz_rolls S3XY
    58
    this has just happened to my s3. what part do i need and where do i get it from? and how do i fit a new relay? cheers
  19. leshkin
    2,500
    1,420
    Hi mate, the flasher relay replacement is a 15 minute job if you have all the needed tools. Go to Stoke Audi section on here and request the part from Dave. Given a chassis number he can give you the correct part. I think it's in the region of 25 pounds, so not too big of a deal.
    To replace the relay (it's one unit, but contains two separate relays - indicator relay flasher and hazard) you will probably be better off by removing the stereo to get a good grip on the panel that covers the top part of the central console (cup holder, ESP buttons and hazard button/relay). I managed to remove this panel without taking the stereo out, because my car had a bigger gap than usual, so a blunt/flat table knife went in there nicely.
    In any case, carefully lever off the panel from the bottom and then pull the panel slightly up and towards you. It's held in with clips, so be careful not to damage any of them.
    The next part is a little fiddly, but you will need to get a flat screwdriver in the corner of the hazard switch and lever it out of place. Once out, it's just a matter of un-clipping the connector replacing the flasher with the new unit (test the indicators at this point) and push it back into place. The rest is in reverse.
  20. Phil74
    Phil74 Member
    70
    I know it's a old thread. Mine are playing up . I signal right and the left indicator comes on for one tick/flash then off and right continues as normal.
    Left one works OK though.
    Cold this be the relay
  21. Orange225
    Orange225 Active Member
    967
    128
    43
    Mines just gone dodgy today, I took the hazard switch out, wiggled it a bit and refitted it, all working again, I've got a new switch on order now though
  22. Phil74
    Phil74 Member
    70
    The hazard switch which you press to put them on ? Or is there another switch.
    I'll give it a go
  23. Orange225
    967
    128
    43
    Yep, the relay is built into it, on mine anyway a3 8p. I'm pretty sure it's the same on the a3 8l
  24. Phil74
    Phil74 Member
    70
    Mines 8p
    I'll give it a go,thanks for your help
  25. Orange225
    967
    128
    43
    Good luck, I just pulled the surround off mine then pulled the red button off, the the whole switch pulled straight out, took me 15 seconds
  26. Phil74
    Phil74 Member
    70
    Worried I'm gonna break something.
    Need to do it though
  27. Orange225
    967
    128
    43
    Not much to break anyway, you can see the small metal prongs that hold it in
  28. Phil74
    Phil74 Member
    70
    Yea I wasn't sure if I would have to squeeze them in which would mean removing the two next to it. I'll have a go Tomorrow
  29. Orange225
    967
    128
    43
    I thought I would, but it just pulled straight out with little pressure
  30. Phil74
    Phil74 Member
    70
    Glad you did yours 1st haha
  31. Orange225
    967
    128
    43
    Got to do it again tomorrow when the new switch arrives though
  32. Phil74
    Phil74 Member
    70
    Was it expensive
  33. Orange225
    967
    128
    43
    £40 from Audi
  34. Phil74
    Phil74 Member
    70
    That's reasonable from Audi .
    Fingers crossed mine is the same problem as urs
  35. Orange225
    967
    128
    43
    Hopefully
  36. Phil74
    Phil74 Member
    70
    Just been out to look (kin freezing )
    I recon mines different to your one I can't see how I'd remove as there all flush buttons
  37. Phil74
    Phil74 Member
    70
    My car is the facelift model so I'm unsure how to remove switch. Searching net now
  38. Orange225
    967
    128
    43
    You'll need to remove the trim around the edge of the buttons, then you'll be able to get at them
  39. Phil74
    Phil74 Member
    70
    Is yours facelift too?
    My one is 2011
  40. Phil74
    Phil74 Member
    70
