Indicators not flashing as they should
Izzy1 Nov 19, 2010
  1. Izzy1
    Izzy1 Vorsprung Durch Technik
    395
    10
    Over the last few days i've noticed that they are not flashing properly on the dash. when i 1st indicate they will blink fast a few times and then continue as normal. but during lunch today they were all over the place and by the end they stopped flashing. inorder to restart the flash i had to cancel and re-start indicating. same problem when turning left or right.
    anyone else ever had this problem?
    I'm think it might have something to do with the wiring as the bulbs are ok.
    any help would be greatly appreciated.
    thanks
  2. CHRIS555
    CHRIS555 DOPE with added OCD
    1,970
    10
    Check the bulbs on the outside - get someone to play with them in the car whilst you see what is going on outside, sometimes that would suggest that a bulb has gone - maybe also try taking the bulbs out and putting them back in - may or may not work?!
  3. camouflage
    camouflage New Member
    12
    It sounds like you need a new indicator relay. I just replaced mine after a similar problem and they are as the should be now.
    The relay is built in to the back of the hazard warning switch. it looks like this[​IMG]
    They should only cost about £20 to £30 and its very easy to replace.
    Here is a link to a how to:
    http://www.craigmurphy.com/blog/?p=661
  4. Izzy1
    395
    10
    Camo - looks like i need the relay switch. i'm having the same symptoms as the guy on that link.
    i'll try picking a relay from the local scrappy if the price is right. wonder if GSF supply this part??? hmmmm
  5. Geeman
    Geeman Low Life
    1,318
    Yep... that's definitely the hazard warning switch/relay that needs replacing. It did exactly the same thing in mine. It's a common fault!
  6. Izzy1
    395
    10
    Does anyone know where i can get one from apart from the stealers? they want £42...
  7. aragorn
    18,139
    765
    £42 really isnt too bad...
    You could pay a tenner for a used one and it could pack up next week.
  8. Izzy1
    395
    10
    is this a dealer only part?
  9. aragorn
    18,139
    765
    Yes.
    TPS might be able to get you it a bit cheaper.
  10. Izzy1
    395
    10
    i reserved one at my local this morning. will pick up on my way home. don't have a choice.
    cheers guys. nice to know when you have a problem someone on here has the answer. :eek:)
  11. Izzy1
    395
    10
    update!
    i managed to get a switch from euro car parts this morning. had a look at fitting it but can't seem to get the old one out.
    is there a way without ripping the whole dash apart?
    it's a facelift model.
    cheers
  12. Izzy1
    395
    10
    all is working as it should now.
  13. aragorn
    18,139
    765
    For completeness: How does the switch come out?
    I think it probably just pulls out the front, but it'd be useful to know for future reference.
  14. Izzy1
    395
    10
    pulled on the fog light switches and they came out with out a problem, for the cup holder you need to put in a flat screw driver (top right) and lift a small plastic arm thing and then pull and that pops out quiet easy. then you have access to the hazzord switch. flat screw driver on both sides behind the edge and then twist and it pops out. no more then 5 minutes.
