Indicators: Hazard Relay.
Mason-A3Sport Nov 3, 2009
  1. Mason-A3Sport
    Mason-A3Sport Audi Sport
    101
    Hi, Done a bit of research on the forum, turns out that i have a problem a few other user's have come across, the indicators, my indicators are not functioning properly they go on and they off after a few blinks. Turns out it could be the Hazzard relay behind the centre console connected to the hazzard switch. Question is where is the cheapest place to pick up a hazzard relay or is it a main dealer part? Also can someone give me a little run through on how to get behind the centre console i.e where the screws are and the easiest way to get in. A bit of help would be appriciated as this problem has occured right before the MOT Due on Thursday, Typical haha. :icon_thumright:
  2. Broken Byzan
    13,237
    466
    Its a dealer only part and it's around £32 iirc. Just remove the trim and swap the hazard switch out and your indicators will be fine again
  3. Mason-A3Sport
    101
    Champion, £32 is fair to be honest, il take a trip down to the Audi garage soon and get one, any Help on removeing the centre console mate?
  4. 1animal1
    9,978
    just get a blunt item behind the piano trim and it will just pop off....shouldnt take too much effort as the clips arent the strongest...then you'll be able to slot the indicator out
  5. djarchive
    djarchive Member
    292
    Apologises for the bump... Could somebody please provide a picture / giude to fitting please?
    Im at a total loss and my indicators now DO NOT work atall. Replaced the fuse / thats still not solved it.
    Thanks people
    Joe
    :notme:
  6. S3 Rav
    S3 Rav Well-Known Member
    2,825
    30
    dj archive if you put hazard relay in the search theres a couple of threads with the pictures on bud.
  7. ianysm
    ianysm Active Member
    1,002
  8. djarchive
    djarchive Member
    292
    Nice 1 Rav.
    Ianysm- cheers for that
  9. keviny997p
    keviny997p New Member
    29
    I have had this problem also in the past.
    Get the hazard relay, remove the stereo using stereo keys and unscrew your way up the dash. Easy to change over the switches. Then start putting things back into place and slide the stereo back in. ----- Bob's your uncle
  10. 1animal1
    9,978
    it may be different for an A3....but the S3 you dont need to take the stereo out....
