Indicators beeping but no trailer is hooked up
S90GAV Sep 28, 2013
  1. S90GAV
    S90GAV Member
    563
    Hi, I just did the wiper linkage repair today, and I don't think it's anything to do with what I've done today, but I noticed when I was arming and dis arming the alarm when every the indicators flashed the car would beep like it would when there's a trailer hooked up, now I've narrowed it down that it only happens when indicating right, this problem wasn't there before I did the wiper fix but I think it's just a coincidence. Anyone got any ideas how I can find the fault? As its driving me nuts when I'm signalling right
    Gav
  2. Greeny233
    Greeny233 It's all about the V8. Team V8 Team Silver Audi S4 Audi Avant Owner Group
    1,094
    385
    My first check would be to have a look at the socket for the trailer electrics. Make sure it's not wet and the connections aren't corroded. Quite common as it's in the elements. Give it a good clean and spray with some WD40.
  3. S90GAV
    S90GAV Member
    563
    oh I forgot to say the previous owner has cut the socket off, I've removed all the tape and had a look at the wires and it's all clean and no wires are touching each other
  4. Greeny233
    1,094
    385
    Trace the wires back to where they have been connected into the vehicle loom and check there are no shorts there. If it's an aftermarket wiring kit it will/should have a smart box as to not cause any warning light issues with the canbus electrics on the car.
  5. S90GAV
    S90GAV Member
    563
    I got it sorted, I found the smart relay hidden in the rear quarter, give it a tap and it seemsto have sorted it. if it happens again ill just remove it. Thanks for your help
    Greeny233 likes this.
