indicator trouble
thegrouch Feb 17, 2010
  1. thegrouch
    thegrouch New Member
    Having some problems with the indicators on my 51 plate S3, and hoping some1 can help? when turning either direction, sometimes they flash and sometimes they dont, when u move the stalk, the indicator light comes on but won't flash, however a good whack on the dash to the left of the hazard switch, makes it start flashing!? The hazards work fine and all indicators flash as they should when arming/disarming the alarm. Wondering if maybe a dodgy flasher unit hence the dwsh whacking (if thats even where its located?) Any help greatly appreciated cheers guys!
  2. s3gav
    s3gav Member
    413
    relay switch mate had the same problem
  3. 1animal1
    9,978
    just pop the black piano trim off, the switch should come out....replace the whole lot as its all one unit..... Audi aint cheap for this bit either ;)
  4. s3gav
    s3gav Member
    413
    as above but i slipped the stereo out first then lever from under the trim, the piano trim chips real easy if not careful lol
  5. thegrouch
    Cheers lads, sounds like fun! Any ideas on price?
  6. s3 Hoggy
    s3 Hoggy Whats going on???
    1,716
    158
    Think I paid £28 mate if you do a search you should find some helpful threads
    Cheers Matt
  7. Nilz
    11,329
    876
    Its around £30 and its a main dealer part only.
    If you know what you are doing, its a fairly quick and easy job to do, however if you are a novice, just be careful when you are taking the surround off, try using a cloth with the scredriver, so as not to chip the piano black finish.
