Indicator switch?
Westy Jul 27, 2010
  1. Westy
    Westy Well-Known Member
    17,440
    1,096
    Guys, is it common for the indicator switch to wear out at the bottom of the stalk?
    The reason I ask is because when I put my indicators on, left or right, the blink a few times then stop. I can also hear a relay or something clicking behind the dash. If I put my hazard lights on I dont get the issue at all so I suspect its the switch. Any ideas?
  2. 1animal1
    9,976
    most likely the relay mate which is built into the back of the hazard switch, dealer im afraid and around the £30-40 mark IIRC...easy fit though - get a small flatblade behind the outer edge of your piano black dash piece and lever it out (only two small clips which arent held that tightly) nothing to break dont worry....then you'll need to get the switch out, you'll work that bit out yaself ;)
  3. Westy
    17,440
    1,096
    Would the relay not effect the hazards as well?
  4. 1animal1
    9,976
    nope not always...... depends if it has seprate circuits....i had pretty much exact same issue as you, except mine stopped working altogther yet hazards worked IIRC
  5. Nilz
    11,273
    845
    I believe they work off the same relay, so im pretty sure it will be the hazard relay.
  6. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,117
    1,956
    They both work off the same relay which is the hazard switch....think its 30 quid ish
  7. SnoopS3
    SnoopS3 You cant beat German
    69
    I am having this problem too. Thanks for the advice.
  8. 1animal1
    9,976
    your very welcome, send your cheque to.......
  9. Westy
    17,440
    1,096
    Tim, just meet me at my Audi dealer and you can stick it in after the parts man has!!!
  10. S3 TAM
    S3 TAM Pocket now empty
    624
    10
    Sounds like fun which Audi garage. LOL
  11. voorhees
    16,117
    1,956
    oh and PM pjmspeedy as he can get OEM parts cheaper than the stealers
  12. Westy
    17,440
    1,096
    How do I get the old relay out? Ive just prized off the black trim (and marked it grrrr) and i'm guessing i have to remove the 2 hex/torx bolts then done?
  13. s3 Hoggy
    s3 Hoggy Whats going on???
    1,716
    155
    It comes out much the same as a head unit mate, you need to get somthing thin down each side and push the clips in before you can pull it out
  14. s3 Hoggy
    1,716
    155
    I used two large thick paper clips, I made them into a long L shape then flatened them down with a hammer. Then you can slide them in above the clips, pull them back to sqeeze the clips in then you should be able to pull the switch out
  15. Westy
    17,440
    1,096
    Well I got it changed but it didn't turn out to be simple! The wire on the back of the connector block was all caught up behing the console so the relay wouldn't slide out. I had to take the head unit out and get my hand behind the console and free up the wire so I could get it out. Mission or what.
    Anyway its all done now and it work so thanks guys. I also have a nice new indicator click noise due to the new relay.
  16. 1animal1
    9,976
    was gonna say expect a new click....feels like a different car doesnt it :)
  17. Westy
    17,440
    1,096
    It doesn't sound like a cheap click any more, it's more Audi like now.
  18. 1animal1
    9,976
    does it feel like a bit of a different car though? i thought mine did for the first few drives after changing
  19. Westy
    17,440
    1,096
    Yeah it feels much faster now :sly:
    To be honest though it does have a more of a modern feel with a nice crisp click instead of the old faint **** one.
    I cant believe we're talking about indicator relay clicks :whistle2:
  20. S3 TAM
    624
    10
    I might have to get one for the new Audi feel.....
  21. 1animal1
    9,976
    surreal aint it :)
  22. SnoopS3
    69
    Have you got the Part Number for the relay switch. I need to order one but need to make sure its the right thing i get. Cant just nip into town and get one as im in the middle of the North Sea!!
  23. 1animal1
    9,976
    just ring Audi up, as long as you stipulate either facelift or non they will be able to find it
    either that or join vagcat
  24. Westy
    17,440
    1,096
    Its such a common fault that the Audi parts guy I spoke to said "ah yes, I know the part you mean" as soon as I mentioned hazard warning light relay. The hazard button and relay is all one part so you'll get a new button too.
  25. s3 Hoggy
    1,716
    155
    Just had s little dig in my parts box, The part number is:
    8l0 941 509 P
    This was the correct part number in march 2009
    Cheers Matt
  26. SnoopS3
    69
    so i phone Audi Aberdeen last week and say" Hi there. Im after the Hazard realy switch for a facelift S3. Reg X6** ***. Common fault apparantly" "ah yes" he replies "we've got that".
    Get it delvered to my ol' mans house.....wrong part!! Idiots!
    ome today so i'll pay them a visit with that part number
