Indicator stork removal
floyd 1.8 turbo Jun 17, 2009
  1. floyd 1.8 turbo
    floyd 1.8 turbo Mirror, Signal, Outmanoeuvre
    632
    Can anyone give me any advice on fitting a new indicator stork on my b5? Any hints or tips at removing steering wheel etc would be cool, it'll save me spending any more hours on it that are needed
    thanks
  2. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    hi its stalk not stork... lol
    anyway not excatly what you want but should point you in the right direction
    Linky
    HTH
  3. CraigG
    CraigG Member
    190
    Basically you remove the airbag, then the wheel, then there are two bolts that run thru the stalk holding it (and i think the cowling) on.
    Be sure not to move the contact ring when you remove the wheel, if it doesnt go back on in the same orientation you will likely break the coil inside it when you steer.
