Indicator Problem
pazaz Mar 4, 2005
  1. pazaz
    pazaz Member
    323
    My Indicator has started playing up. After I switched it off earlier it kept ticking as if it was still on (only faster than normal) but it wasnt flashing on the DIS.
    Now it seems to be doing it when ever it feels like /ubbthreads/images/graemlins/froggie_red.gif. I hope my indictors are not flashing as well /ubbthreads/images/graemlins/confused.gif
    Anybody experianced this before?
    Thanx in advance /ubbthreads/images/graemlins/beerchug.gif
  2. bampy
    bampy Member
    92
    Sounds like the indicator relay is on the way out or you have a bad earth on one of the bulbs. Either way it is a simple fix. Any auto-electrician can sort it out.
  3. LeeW
    LeeW Member
    67
    Indcator relay (hazard light switch) is a common problem, could be that.
  4. pazaz
    pazaz Member
    323
    [ QUOTE ]
    [/ QUOTE ]
    Its happening all the time now and the noise is coming from behind the hazard warning switch, so I think you may be correct LeeW /ubbthreads/images/graemlins/beerchug.gif
    How do I go about Fixing it?
    Anybody know how I take the Piano trim off around the hazard switch to have a look?
  5. LeeW
    LeeW Member
    67
  6. pazaz
    pazaz Member
    323
    Thats spot on cheers LeeW, thats all I need now is how to take the sterio out. /ubbthreads/images/graemlins/confused.gif
    This forum is the Mutz Nutz /ubbthreads/images/graemlins/bravo.gif
  7. jpda4
    jpda4 Member
    129
    21
    thats the easy bit lol
    well kind off
    i managed to replace my relay with out causing damage to either the car or myself /ubbthreads/images/graemlins/woohoo.gif
    read on here you can use a junior hack saw blade to fit in the slots instead of buying the proper tools to remove radio and it worked for me /ubbthreads/images/graemlins/ok.gif
