indicator malfunction
SnoopS3
You cant beat German
Hello,
i am having problems with my indicators at the moment. I know its not any broken bulbs etc as the hazards are working fine. When i indicate to go left or right the lights will flash 1, 2, 3, maybe 4 times then just stop. I'm thinking its a wire/connection in the stock or somewhere.
Has anyone had this problem before? and if so is it an easy fix??
relay switch has gone mate had same problem with mine
Defo the relay mate, its a common fault. You just need to replace the hazard switch(which has the hazard and indicator relays in it) they are about £30 from the dealers iirc
714
852
