Indicator / hazard flasher problem.
Discussion in 'TT/TT-S/TT-RS Forum' started by Big D, Oct 24, 2006.
  1. Big D
    Big D New Member
    Oct 24, 2006
    Could anyone could be kind enough to help out?
    My 2002 225tt has developed a indicator / hazard / alarm flasher problem.
    1. Hazard switch only operates the indicators on one side only.
    (is this simply a relay problem?)
    2. Indicator stalk fails to operate indicators or is irratic.
    3. Alarm arm/disarm only operates indicators on one side, same as hazards.
    (does alarm operate same relay as hazards?)
    The Hazard /alarm flasher fault occured before the indicators stalk failed.
    Thanks,
    D.
  2. Advert Guest Advertisement
  3. AwesomeSarah
    AwesomeSarah Member
    Oct 24, 2006
    726
    Hi Mate
    This os probably down the the hazzrad switch
    These have a relay at the back of the switch
    Very common fault on ALL the VAG cars
    Not expensive either
    Sarah
  4. madvw
    madvw Active Member
    Jul 26, 2005
    2,489
