In Two Mind's
CMD Oct 5, 2010
  1. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
    I'm in two mind's about the alloy trim the run's along the back bumper (below the boot).Should i paint it satin black to match the front grill's or leave it alone.
  2. simon.m
    simon.m Active Member
    2,747
    what colour is your car mate if its red silver or any light colour id say black would look ok me i like the alloy my self
  3. CHRIS555
    CHRIS555 DOPE with added OCD
    1,970
    10
    Find yourself a second chrome trim, then do it! That way if you don't like you can swap it back - I've done the same thing for my rear diffuser - or, although i'm not sure of this, you could go to a print / design shop and have it wrapped in some black memory film to see what it's like, then if you don't like it just pull the film off.....
  4. simon.m
    2,747
    or you can put some black electrical tape on it for a day or two to see if you like it this will give you the same look so you will no if its for you or not
  5. CMD
    3,015
    17
    Akoya Silver.
  6. CMD
    3,015
    17
    Chris i'm the same. I have bought spare top and lower grill's as i have painted one set satin black i also have a spare brushed alloy interior cabin trim (full set) also bought a used cam cover which has now had a make over for next summer. I was thinking of covering the rear alloy trim with satin black vinly.
  7. crazypainter
    crazypainter Member
    594
    You got any other 'chrome' on the car? I have the same on my car but no chrome pack or anything else like it so not sure what its supposed to tie in with, looks random to me??
  8. CMD
    3,015
    17
    No chrome on mine the only item's that are chrome are the front and rear ring's and the A4/ 1.8T badges all window trim's are black as standard.
  9. quattrojames
    14,050
    578
    I did mine Avus silver to match the wheels/mirrors/door rings etc, but that wouldn't really work for you.
    How about wrapping it in CF to look a bit different?
  10. quattrojames
    14,050
    578
    I just found THIS while I was browsing, if it's of interest.
  11. CMD
    3,015
    17
    Jame's i thought you struck gold. I was just about to hit the BUY IT Now button before i read the ad again this trim is for an Avant only (gutted)
    But thank's James well spoted.
  12. quattrojames
    14,050
    578
    Nah it's my fault mate - I thought I had struck gold as for some reason I thought you had an Avant - dunno why :think:
    The two aren't compatible - BTDT ...
  13. CMD
    3,015
    17
    I'm warming up to the idea of Satin Black vinly as it's easy on easy off.
  14. jd26
    jd26 Member
    293
    Coll how is this strip removed bud? Not stuck on?
  15. crazypainter
    crazypainter Member
    594
    There are loads of little tabs on the back. I bought a spare strip and its in primer , just need to paint it and lacquer it.
  16. quattrojames
    14,050
    578
    You need a small flat screwdriver and carefully starting one end prise it away from the bumper. Its a fiddle and very fragile, and there are LOTS of little tabs which break very easily!
  17. CMD
    3,015
    17
    Would it be possible to vinly wrap it whilst it's on the car.
  18. CHRIS555
    1,970
    10
  19. quattrojames
    14,050
    578
    It would be easy for a man of your caliber to take it off Colin.
  20. CMD
    3,015
    17
    I get nervous working on my own car.
  21. quattrojames
    14,050
    578
    I'll bring a screwdriver to AITP...
  22. CMD
    3,015
    17
    James i have a shed load to do to my car ,the rear trim mod will be shelved if i run out of time..
