In search of a dashboard switch/button - like the ESP one...
brixo Jun 24, 2011
  1. brixo
    brixo Member
    79
    Hi all,
    I want to be able to turn on an external amp in the boot of my B7 Avant - the "remote" cable from the Bose seems to be a constant feed and not really a switched feed.
    I want to wire the "remote" wire to a switch on the dash to manually turn the amp on/off. I would like to find a switch that would replace the blanking plates next to the ESP button on the dash...
    ... does anyone know the part numbers or where I can buy one?
    Many thanks...
  2. Chris79
    Chris79 On my 3rd A4! RS4 next???
    159
    There is a parking distance control button on eBay at the moment.
    Kufatec did sell several buttons but last time I looked I couldn't find them.
    Chris
  3. rowdyboy
    rowdyboy Member
    804
    19
    I saw quite a few on eBay yesterday when I was searching for something else. It just takes having a look and a bit of patience.
  4. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group s tronic
    3,893
    724
    There is permanent live to the amp & switched live however the amp & head unit only fully switches off several minutes after the ignition key is removed.
    Is there any reason you cannot take a new switched live feed from the fuse box on the drivers side, as that will be far quicker, & you don't have the worry about forgetting to switch the amp off, and end up with a flat battery.
  5. hades-
    9,481
    646
    when i had my amps fitted in the my cab the switched on and off woth the radio why cant you do it that way ?
  6. brixo
    brixo Member
    79
    Thanks all. I didn't realise that the switched live stays ON until you lock the car. Very bizarre. I think I will do it that way now.
    In previous installs, the remote has been immediately.
    Many thanks people.
