in car temp
simon.m Mar 24, 2010
  1. simon.m
    simon.m Active Member
    2,747
    so as iv not had climate control before can any one tel me if 18c is the lowest it goes down to before it says low.
    just seems strange that i cant got to say 15c
  2. wallacr
    wallacr Member
    260
    I know, it's a right pain. They did change it to 14 in the B7 I believe. I tried a B7 module in my car and everything worked ok except for rear heated windscreen, so I guess it's a slightly different setup in the newer climate control models.
  3. mikeh126
    mikeh126 Member
    152
    Same as mine - 18c or 64f, and then it goes to Lo.
    When Lo is showing, I presume the air con (cold) unit comes on, without measuring the temp inside the car.
  4. wallacr
    wallacr Member
    260
    Yes exactly and it doesn't take too long to get too cold, I generally have mine on 18 or Low and not always on Auto, sometimes I'll just have the fan on 1 bar, that seems to help a bit
  5. simon.m
    2,747
    thats what i thought so its 18c or frezzzzzzzzzzzzz
  6. wallacr
    wallacr Member
    260
    Pretty much :(
  7. chrisash32
    chrisash32 Member
    573
    hmmm.. when mine is on low it doesnt seem to freeze.... in fact it still feels quite warm.. think i may have an AC issue :(
  8. wallacr
    wallacr Member
    260
    Sounds like there's a problem, it could just be gas, it could be the connector has corredded like it did on mine or it could be the compressor.
    Under the bonnet on the back left there are two a/c pipes, when your engine is on and a/c on low one should be freezing cold and the other warm, if not it's defo one of those above I would think
  9. chrisash32
    chrisash32 Member
    573
    cool, will give that a try, thanks :)
  10. simon.m
    2,747
    i have ac problems my self think the compressor is not kicking in :crying:
  11. wallacr
    wallacr Member
    260
    Hope you both get them fixed soon
  12. chrisash32
    chrisash32 Member
    573
    is there any way i can test the components with vag-com??
  13. wallacr
    wallacr Member
    260
    There probably is, oddly it showed no faults when mine went, but someone else who's more clued up on the in's and out's of vag-com will be able to tell you, perhaps in the VCDS forum if not here.
  14. simon.m
    2,747
    im told you can find it with vag.com and i no audi can pin point it or so they say.
  15. A4 nut
    A4 nut Member
    351
    If your air con isnt working then the red econ light stop on and stops the compresser from working, you need vag com to read the fault code and hopfully its a pressure switch.
  16. wallacr
    wallacr Member
    260
    Am I right in thinking that's just if it's a gas/pressure issue? As I never had that happen on mine.
  17. simon.m
    2,747
    i changed my pressure switch and the light whent off but still dont work and i tryed toping it up too and still nothing but some times the light dose not go off.
  18. defsix
    defsix Member
    181
    Mine goes down to 16c then low.. with cold air blowing then. Didn't work up until a few days ago changed the G65 Thrust Sensor ( thanks pjm ) 5 minute job to fit. perfect.
  19. quattrojames
    14,068
    585
    Vagcom will detect most aircon fault codes, but it obviously won't tell you if it's low on gas! Chris it sounds like yours is probably 'a bit' low on gas, but not low enough to cause the compressor to switch off. It does this to protect itself as the gas supplies the lubrication, when the compressor isolates itself is when the ECON light comes on.
    The ECON light is usually either the high pressure switch or low on gas. If it's low on gas get it pressure tested before refilling as if there's a leak you need to sort that out first.
    I think all B6's only go as low as 18, (but maybe some very late ones go to 16...?) and the B7's go to 16. A B7 climate control can be retrofitted, but as mentioned requires a mod to keep the heated rear screen working, Woorlord can help you with this. The B6 aircon is just notoriously inefficient! For some reason an Audi 18 feels warmer than other manufacturers! Mine will blow lovely ice cold air when set to LO, but as mentioned it's a PITA as you have to turn AUTO off or the fan goes flat out - and then when eventually you get too cold and have to raise it 18 it blows hot air! :tocktock:
    At the end of the day though, it will keep you cool if it's working well :cool:
  20. wallacr
    wallacr Member
    260
    That's good to know, wish I'd kept that B7 unit now, ah well
  21. simon.m
    2,747
    what is the G65 Thrust Sensor and where is it
  22. quattrojames
    14,068
    585
    It screws in the N/s of the condenser, its a pretty easy change and you shouldn't lose any gas in doing it:
  23. BigAardvaark
    BigAardvaark Active Member Team Scuba Audi A4
    183
    52
    Just for info, my '01 B6 only went to 18. This '04 goes to 16. '04 seems to be the year as my TT too only went to 18.
  24. simon.m
    2,747
    thanks james thats the bit iv change and still not working :keule:
  25. quattrojames
    14,068
    585
    Have you had the system pressure checked?
  26. simon.m
    2,747
    well i got my self a halfords top up one and put it on and it says it was fine so i have a new bottle of gas and gage but no ac
  27. defsix
    defsix Member
    181
    Just
    slide out the passenger headlight and it's there on the left, 2 spanners and it's off. No gas loss, but check to make sure the rad piece is lubricated , this means you've plenty of gas with oil still circulating.
