Immobiliser problems :(
Mr.T Feb 8, 2012
  1. Mr.T
    Mr.T New Member
    After doing a search on the forum and reading various threads i have a faulty immobiliser. I have tried all the "quick fixes" but none of them have worked. I have ordered a new ignition barrel with two new keys from audi. Once i have fitted this will i have to get it coded to the immobiliser?
    Thanks Scott.
  2. aragorn
    18,538
    865
    hmm, if the barrel has been manufactured to the original key code for your car (which it should have been!) then you can simply fit it and continue using your existing keys.
    If it hasnt, then you'll need to get the new keys coded to the immo, and will also end up with a different key for the door and the ignition barrel...
  3. Mr.T
    Mr.T New Member
    Yeah its a new barrel and keys! Audi said unless im 100% sure the locks havent been changed in the cars life they wouldnt recomend ordering a original set!
  4. Mr.T
    Mr.T New Member
    How will i go about getting them coded?
  5. hades-
    9,481
    646
    every time iv had that problem
    iv changed the wire that joins the reader coil thingy to the other part
    and its worked never had to get new ignition
    thers a few ppl around that can code
