Immobiliser light on dash doesn't flash?
alinghi9 Aug 29, 2011
  1. alinghi9
    alinghi9 Member
    67
    Hi
    Noticed that normally the red light flashes on top of the dash comes on when the car is locked and recently noticed that now this does not happen, anyone know why this would be the case?
  2. audigex
    audigex Active Member
    600
    46
    To point out the daft obvious one... bulb gone?
  3. jamessg1962
    jamessg1962 Member
    123
    ,LOL
    Its an L.E.D so doubt very much it will be that , try to check if your alarm /imobilser is actually working.Leave window open lock car wait a few minutes then stick you hand in .Alarm should opperate. If it doesn't check fuse for alarm .
    Fuse 35 left hand side of dash pannel inside car ,should be a light brown fuse 5A.
  4. jungleman
    jungleman Well-Known Member
    2,035
    42
    its actually a very very dull light, i can only see mine at night its that dull!
  5. NHN
    29,596
    1,782
    The led by the sun sensor is controlled via the drivers door, on earlier modules there was a stupid 2 pin connector in the drivers door that had a black wire that came into the door, went to the connector, then connected to the door card, which then went down the card loom & connected to the door module, reason being was it connected to the main 32 pin connector which only came of with the door card, doh, the stupid thing about it is, the wire was relocated on later door modules to the main 20 pin connector, thus no round the houses anymore, why they didnt do this originally defies me, I relocated when I upgraded door modules.
    Anyway, so if fuse not blown & alarm not working, drivers door would be my next step, possibly the lock itself as this has 3 microswitches iirc inside the lock that signals states.
    You mean check his alarm, immo & alarm completely seperate systems & dont interact with eachother :)
    Yeah very true, I have to stick my nose on it at night to verify its working lol.
  6. alinghi9
    alinghi9 Member
    67
    yeah i was just going to check if the light was visible during the day?
    if the alarm doesn't trigger what's the worst case scenario or what would I need to replace?
    thanks
  7. NHN
    29,596
    1,782
    Check it at night, not day as its ridiculously dim.
    What would you need to replace, until we know whats going on thats not a question anyone can help with, once you know about the led or test alarm, then go from there, next would be a scan of the car, then consider parts.
  8. paddy
    paddy Audi=we just sell em mate, we can't fix em.. Team Ibis Audi S3 Black Edition DSG
    5,405
    225
    Alarm not working ?? could be postcode related. What's your exact address ?
    No dont ! :o.k:
  9. NHN
    29,596
    1,782
    We all love Paddy lol
  10. FranA3
    FranA3 FMDETAILING Site Sponsor Regional Rep Gold Supporter Team Brill Red Audi A3
    7,265
    365
    as the others have said the led is very dim i can only see mine at night even then its not very bright at all
  11. vw754
    vw754 vorsprung Durch Technik
    2,354
    58
    just to slightly go off track here.......can it be upgraded for a brighter one?
