Immo Defeat, possible to reverse it and recode the keys to the immo?
mikem1 Jun 29, 2012
  1. mikem1
    mikem1 Golf with BAM Engine
    57
    Having done an engine swap, the ECU was defeated to enable the TT set up to run in my Golf. Is it possible to reverse the Immo defeat? I assume you'd need the SKC code and go from there?
  2. beachbuggy
    beachbuggy Well-Known Member
    1,931
    202
    Yes it is possible, if you send me the ecu and some beer money I'll happily do it for you.
  3. mikem1
    57
    Excellent news, I'll send you a PM as have some other questions.
  4. mikem1
    57
    Just to clarify the ignition key and clocks are the cars originals, the ECU is new and defeated, is it possible to reverse the Immo defeat and code everything back to the ignition key?
  5. aragorn
    18,662
    878
    The ECU will need the defeat removed, then you'll have to code the ECU to the cluster like normal, you'll need the SKC for both the cluster and the ECU to do that.
    The only issue you might have, is if your Golf is IMMO2 and the ECU is IMMO3.
  6. mikem1
    57
    Yes, I believe the car is IMMO2, the ECU is an AMK ECU 8N0906018J.
