Immo chip swap Audi a4 b5
solidarity Sep 3, 2012
  1. solidarity
    solidarity New Member
    Hi !
    I'm new to this forum so i hope i posted to the right place.
    Here's my Questsion:
    Which chip on the ecu's motherboard is the immo chip ?
    I found a post in this forum and there's a user who has done this kind of immo chip change before.
    here is the link :
    http://www.audi-sport.net/vb/a4-s4-...-progress-thread-std-scroll-eliminator-5.html
    My ecu looks pretty much the same, so i assume it's the same chip on my ecu ?
    I would like to remove the immo chip from the old ecu and solder it to the new (used) ecu.
    Read from another forum that it actually works, but there was no picture.
    Thank you !
  2. aragorn
    18,444
    848
  3. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    :iagree:
    Wot he said.
    (Just don't play with your mates' TT 9999999999999 :whistle2:)
    Removing and refitting chips is possible, but even under the best of circumstances it will thermally stress the silicon, so make it more prone to fail. If you can't get VagTacho, get a 'Man in' for some beer tokens - it will be easier and cheaper in the long run
  4. solidarity
    Thank you for answering !
    At first i planned to order the Vagtacho tool, but then i found out the other way (to solder the old ecus immo chip to the new one).
    Quess i have to go with the vagtacho.
  5. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,913
    166
    VagTACHO is such an easy program to use... you'll be fine ;)
  6. HibiscusS4
    HibiscusS4 Member
    97
    With the removal of the chip method is it possible to remove the immobiliser? I am guessing the Audi has the ECU linked to the key fob like a lot of cars but is there a way to transplant the Audi ECU into another car without having to move the entire alarm system (and closkc?) Across?
  7. AR-rkon
    1,913
    166
    VagTacho... but IIRC you will need the old SKC code
  8. LeeT
    LeeT Member
    429
    Has anyone got a link to a reasonably priced vagtacho?
