Imminent RNS-E Install...
XXXCorps Jan 6, 2012
  1. NHN
    29,328
    1,708
    No need to extend wires as per stated, peel coroplast back & route to new 32pin connector, its plenty long enough :)
  2. rOb_A
    rOb_A Active Member
    1,488
    no nothing else needed other than the 32 pin connector & coding NHN?
    lesson learned is get to know people who know what they're on about :blush:
  3. lgooch
    lgooch Well-Known Member VCDS Map User
    1,112
    143
    Correct
  4. downtothebone
    downtothebone Active Member Team Scuba Audi A3 Audi Cabriolet Owner Group S-line owners group
    608
    105
    43
    Having swapped my BNS (Navigation) 5.0 unit for an RNS-E MK II (Glossy surround) and not done any coding or wire swapping (I thought it was plug and play ...) I've just run a VAGCOM diagnostics and got the following fault codes ...
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
    Component: RNS-E PU EU H06 0200
    Revision: 0000012S Serial number: AUZBZ7MD206483
    Coding: 0225725
    Shop #: WSC 00295 211 124470
    VCID: 3461228A57D224B8F5D
    4 Faults Found:
    00878 - Connection to Speaker Front Left
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 42
    00879 - Connection to Speaker Front Right
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 42
    01303 - Telephone Transceiver (R36)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 196
    Mileage: 16862 km
    Time Indication: 0
    Date: 2012.07.20
    Time: 16:58:15
    03157 - Functionality limited due to Communications Disruption
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 196
    Mileage: 16862 km
    Time Indication: 0
    Date: 2012.07.20
    Time: 16:58:04
    Freeze Frame:
    Bin. Bits: 00000100 00000000
    Bin. Bits: 00000000 00000000
    Bin. Bits: 10000000 00000000
    Same faults under the radio section. What do I need to do??
  5. NHN
    29,328
    1,708
    Check your coding for systems fitted to the car.
  6. K13 ASJ
    K13 ASJ Member
    192
    the three aux wires i have are, yellow green and grey, can anyone tell ne which is left/right/ground?
  7. Wax Attack
    Wax Attack Member
    57
    Sorry to hi jack but i can't PM yet, NHN have you received my email ref an RNS-E and CC ? thanks.
    Simon
  8. K13 ASJ
    K13 ASJ Member
    192
    i figured it out, aux now working woohoo!
