Imminent RNS-E Install...
XXXCorps Jan 6, 2012
  1. XXXCorps
    XXXCorps Member
    194
    27
    Hi all,
    I've bought an August 2011 RNS-E which I'm tentatively going to attempt to fit to my May 2011 A3 Black Edition this Saturday. My car has Bose, Bluetooth phone prep, glovebox USB and rear parking sensors. To say I'm nervous about this retrofit is an understatement so any input from you guys would be greatly appreciated as I suspect I will be buying the services of someone to get my car reprogrammed at some point! I live in Baxenden, BB5 2xx area in Lancashire so would love any suggestions of any relevant VCDS coders out there that live/work locally...
    Thanks,
    Peter
  2. Kelza
    Kelza MODERATOR Staff Member Moderator Audi RS3
    3,078
    604
    Hi peter if your unsure about fitting it get a member to fit and code it in for you ,, i always do...
    dobbysline and XXXCorps like this.
  3. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter
    26,639
    9,623
    Nigel, user NHN may be just the guy your looking for.
  4. NHN
    29,331
    1,716
    It will need some wiring changes & coding to make it work fully, so as advised, someone who 1st knows what they're doing & 2nd has the tools to complete the job for you.
    Give me a shout if my services are of use.
  5. XXXCorps
    XXXCorps Member
    194
    27
    Where are you based Nigel?
  6. paddy
    paddy Audi=No fault code, no idea
    5,184
    137
    Nige is in Kent but travels :)
  7. XXXCorps
    XXXCorps Member
    194
    27
    Thanks for that Paddy; I'm in Lancashire so quite a few miles away from there unfortunately...
  8. gary3306
    gary3306 Active Member VCDS Map User
    989
    41
    Jonny (username jb0o) lives in Cleveland, and he is a well known Audi retrofitter with his own business. He'll be a bit closer for you. PM him.
  9. wesley
    wesley Giac Extreme+!! Lovin it
    350
    23
    I'm in Manchester and can install and code if needed.
  10. XXXCorps
    XXXCorps Member
    194
    27
    Wesley you may just be the lifesaver I need; could you possibly PM your number etc; I'll do the same now...
  11. XXXCorps
    XXXCorps Member
    194
    27
    Just want to say thanks for comments and messages guys on this issue; Wesley is kindly doing the install and coding for me tomorrow so crisis averted!! :)
  12. Kelza
    3,078
    604
    Top bloke endless coffees :arco:
  13. MattyW19
    MattyW19 Member
    401
    I fitted a RNSE (September 2011) to my car just over a week ago (to my 2011 a3 s line).
    At first I found it quite simple to remove the radio - Fittings off the cables can be abit fiddly though! After installing the unit, I marked my chrome trim very slightly above the hazard button (so be careful not to rest the RNSE on there as it will damage it).
    My car seems to be working fine without the coding, it has instructions on the DIS and the MFSW works like it use to. However the AUX is no longer working.. which was a downfall but i've decided not to have it coded.
    One mistake I did make though was the GPS cable goes at the top of the RNSE unit at the back (blue slot).. I was putting it in the radio one :/ Oh and after you position yourself on the map.. it may tend to go off course for 5 - 10 miles, then it calibrates itself and works perfectly.
    With you having bose though, I'm sure I read something about a pin having to be changed?!
    Hope this helps
  14. Cruiser89
    Cruiser89 Advanced In Car Tech Site Sponsor
    1,484
    221
    I posted up a small guide on my thread... Hope it helps.
  15. XXXCorps
    XXXCorps Member
    194
    27
    Thanks again for the posts there; they're incredibly helpful and informative... :)
  16. XXXCorps
    XXXCorps Member
    194
    27
    Just wanna say again a very very big thanks to Wesley for fitting and coding my RNS-E; you were great fella and looking forward to hooking up again sometime...:beerchug:
    Kelza likes this.
  17. Kelza
    3,078
    604
    Leds next lol ...:arco:
  18. Dmrqwq
    Dmrqwq Active Member Team Navarra Team V6 Audi S4 Audi Q5
    139
    166
    43
    Im wanting to do exactly the same - can you point me in the right direction? Im from County Durham so looking for a northerner who knows the ways...
    Im tempted to try it myself but dont want to muck up my brand new A3 Black Edition...
  19. Sandra
    26,639
    9,623
    Pm nigel, user NHN. He is top guy and he travels as well. :) x
  20. mike foster
    3,967
    jb0o is in Hartlepool ( see post #8 ) and does this sort of thing for a living. He will soon sort you out. Send him a PM.
  21. downtothebone
    downtothebone Active Member Team Scuba Audi A3 Audi Cabriolet Owner Group S-line owners group
    610
    105
    43
    I went from a BNS5.0 Navigation head unit to the latest RNS-E model - do i need to recode and wire swap? I have BOSE - all appears to be working
  22. NHN
    29,331
    1,716
    Well yes depending on what year & if any adapters used, wire swap maybe needed, coding for sure will need to be checked & changed accordingly.
  23. downtothebone
    610
    105
    43
    Right - old unit was made in 2010 new one in 2012 and car is a MY11. I simply plugged all the various connections into the right places. I did have to turn down the bass setting on the new unit - it was just too overpowering.
  24. NHN
    29,331
    1,716
    Still needs coding checking tbh, does it have a dsp menu under sound
  25. rOb_A
    rOb_A Active Member
    1,488
    NHN dont know if N8 got hold of you, as i meet up with him yesterday but I have two error (see below) and i also noticed that the Bose cable was still in pin 5. do you think my errors will go if i can relocate the Bose wire. i take it the grey wire is the aux? the car is MY11/12 if that helps
    2 Faults Found:
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 53
    Mileage: 2112 km
    Time Indication: 0
    Date: 2012.06.06
    Time: 13:08:02
    02005 - Coding Pin
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 53
    Mileage: 2112 km
    Time Indication: 0
    Date: 2012.06.06
    Time: 13:08:02
  26. NHN
    29,331
    1,716
    Yes if you have Bose then move wire which then requires codes cleared & will lose the coding pin error, the antenna error is because you have retro'd rns in a post late 06 car & needs antenna fix for it aswell, which I can do when you have the audiopilot sorted out & light pack, if still needed that is :)
  27. downtothebone
    610
    105
    43
    Yup DSP->GALA
    VCDS should be with me next week I'm just not sure about the wire swapping bit ...
  28. rOb_A
    rOb_A Active Member
    1,488
    yep still looking for the door handle LED's, audiopilot and footwell lights. What you think the causing the antenna error?
    when you going to N8's next or up manchester way?
    will move the Bose wire, when i can get it out, i though they just clipped out of the housing, any tips?
  29. NHN
    29,331
    1,716
    Yeap so needs coding.
    VCDS next week, did I sell it to you, if so, sorry if I dont recognise your username :)
  30. NHN
    29,331
    1,716
    The post late 06 cars use different antenna system, which needs upgrading to make radio 100% compatible with rns-e which I do often for rns upgrades.
    I'll be up there soonish mate, just working/family away atm, but when back I'll be up there straight away.
    Yeah remove 12 pin housing from quad, then with small screwdriver, oush the little locating clip down & pull the 009 wire out & push into the correct pin, taking note if 7 is connected, then its the aux in that needs to be removed anyway which is wired different on rns-e & you should remove all 3 auxin wires not leave plugged in.
  31. rOb_A
    rOb_A Active Member
    1,488
    All 3, which ones are those? grey, green and ?
    i'll wait till you you come up north lad, would rather get it right :sadlike: :laugh:
    Can you pm me a price, so that i can sort my funds out. hoping to get this sorted or the rsne is going, as the sound can go quiet sh*te
  32. NHN
    29,331
    1,716
    Yes I'll PM this afternoon if thats ok as gotta go out now :)
  33. downtothebone
    610
    105
    43
    Yup Garry - paid on Friday ...
  34. rOb_A
    rOb_A Active Member
    1,488
    that would be great lad, enjoy the day :yes:
  35. NHN
    29,331
    1,716
    Aha I thought so, sorry mate so many usernames, cant remember them all :)
  36. rOb_A
    rOb_A Active Member
    1,488
    don't forget me NHN fella :3sadwalk:
  37. rOb_A
    rOb_A Active Member
    1,488
    Hello NHN, pm me lad :friends:
  38. Dmrqwq
    139
    166
    43
    Im still 50/50 on getting the RNS considering the number of reported thefts and the difficulty in finding one at a reasonable price which isnt nicked (one ebay seller told me that a "couple of scrapes on the casing are to be expected when the unit is withdrawn" - needless to say I havent purcahsed from him!). If I can find one at a reasonable price and even someone to fit it in the north east then I might well go ahead!
  39. mike foster
    3,967
    jb0o (forum member) is your man - based in Sunderland I think. Send him a PM.
  40. Dmrqwq
    139
    166
    43
    When I work out how to I shall! Does he supply units?
