I'm sure this has been asked before many times but
mo0 Nov 12, 2004
  1. mo0
    mo0 New Member
    What's the most common method of getting an amp power lead from the battery to the boot?
    Im sure there's a post that tells you how somewhere but i can't find it!
  2. JamesT
    JamesT New Member
    Usually on most cars there is a small whole in the back of the engine bay near the glove box that you can squeeze it through. If not it's suggested that you drill one and plug it with a gromit to avoid water seeping in. I haven't fitted an amp to my A3 yet so not sure if this hole is there or not. check it out.
  3. RichA3Turbo
    RichA3Turbo ...Watching you! Moderator
    5,089
    [ QUOTE ]
    [/ QUOTE ]
    DRILL A HOLE? NOOO!
    If you remove the scuttle panel under the windscreen, you will see the pollen filter on the passenger side. Now under just infront and to the side of this is a rubber blanking plug about 15mm diamter. I made a slit in this and fushed the power leads, and any other leads needed through it. This way you dont have to make and 'holes' and you can run the cable up the trunking behind the airfilter for a nice tidy install. The cable will then drop down behind the glove box just in the right place!
    Rich
  4. mo0
    mo0 New Member
    nice one i found this plug under a pile of leaves earlier but didnt know where it led, ill go do it now /ubbthreads/images/graemlins/tongue.gif
  5. mo0
    mo0 New Member
    ok one more question, i just went for a drive without any of the rear interior in, and under hard acceleration theres a whooshing noise that gets louder as the revs go up, coming from somehting in the BACK of the vehicle? whats that??
  6. foolish3uk
    foolish3uk Member
    455
    nooooo dont use the plug in the top of the scuttle pannel by the pollen filter, there is a plug at the back of the engine bay that you can poke the lead through. if you do it in the top then you are quite likely to get a water ingress( ive seen it loads of times!!!)
  7. mo0
    mo0 New Member
    ok it was the fuel pump
    finally worked it out
    *cough*
