I'm sick of my coilovers!!!
Scott Mar 24, 2010
  1. Scott
    Scott Well-Known Member
    1,306
    126
    I think my Weitec coilovers are creaking really bad. Whenever I go over a bump in the road or a speed bump, even at a very reasonable speed, much lower than I ought to be able to, I get a terrible 'grinding/creaking' sound. It sounds like it's the front left (N/S) but honestly I don't know. They have been on for less than a year, approx 10,000 miles, and it's started happening since the bad winter we've had. Any ideas on what I can do? What it could be? Anything else apart from coilovers? The car is an 09 plate, so hopefully nowt else. I really don't want to take it back to the garage as it's far. It also seems to come and go (ish) but tonight it's been very bad...
    Cheers,
    Scott
  2. V6Pete
    V6Pete Now running on Bentley's y'all
    1,491
    If it's f*cked, then it'll be under warranty. Shocks do fail sometimes, fact of life :(
  3. tobycruse
    tobycruse Member
    289
    I know how you feel! My K&W V3's started squeaking really badly in the winter. I took them back to AmD and got them replaced under warranty, I'm sure you will be able to do the same. Its not about noisy expensive coilovers!
  4. N8
    17,163
    718
    Sorry to hear that Scott, Toby not seen you on here in a LONNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNG time, where you been hiding?
  5. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,473
    611
    I had to replace an FK rear shock when they were on my TDI
    Check for leaks at the bottom of the shocks, maybe take them out and give them a good inspection
  6. s3ollie
    s3ollie Member
    762
    could it be ARB bushes?
  7. Spin140
    Spin140 Well-Known Member
    2,196
    186
    Thats exactly what I was thinking, I'd wager it's the ARBs, just had mine lubricated by Ben at AVP using a liquid grease that thickens up after application the difference is amazing, there was no charge as car was already on the ramps but on the way home whilst driving over numerous speed humps I said out loud " crikey thats up there with a remap !!" - I fell back in love with my car all over again.
    I feel your pain my car was driving me nuts until this simple bit of maintenance caused by the bushes going dry, give it a go
  8. a3rick
    a3rick The Ibis
    222
    You can also buy a dry spray grease, in other words you dont get dust and dirt sticking to the lubricant:idea:
  9. Scott
    1,306
    126
    I hope it's something as simple as that, I really do!
    I've noticed the rear is "creaking" a bit too.......... but no where near as bad as the front.
    It's booked into the garage who fitted my coilovers and ARB's for next Sat, so we'll see!
    Cheers,
    Scott
  10. Scott
    1,306
    126
    Also, it's been 'creaking'/'grinding' when I turn at 10-15mph full lock, does this sound like it could be ARBs too?
  11. N8
    17,163
    718
    What monkeys fitted yours?
  12. tcardio
    tcardio Well-Known Member
    992
    287
    Did you replace the strut mounts and bearings when you installed the coilies?
  13. Scott
    1,306
    126
    I have no idea, I didn't fit them lol.
    Let's say it was the ARB bushes, would this be obvious, or would it be a case of greasing them and seeing what happens?
    If it's a shock, would that be obvious by looking at it?
    I'm taking into into the garage which fitted them on Saturday - but I'd like to know so I'm prepared. :)
    edit - I think they had to reuse the original front ARB bushes as the Eibach kit doesn't come with any? If that makes a difference to anything? Bearing in mind the car is 09 plate (March 09) and they were fitted June 09, so they weren't very old to begin with.
    Scott
  14. tcardio
    992
    287
    I don't know what you chaps do over there but we replace the strut mounts and bearings when we change over to coilovers. It's a common problem where the driver notices knock knock knock over bumps and when driving slow and turning.
  15. Scott
    1,306
    126
    Ahh I see. I don't have a prob with knocking *touch wood* this is definately more of a creak/grind. I'm hoping it's the ARB bushes!
