I'm in trouble...your advice please!
vw754 Jan 18, 2010
  1. vw754
    vw754 vorsprung Durch Technik
    2,354
    58
    Apart from the alarm going off and dash display showing the boot to be open,ive now got a couple of other issues.......when i switch on the ignition....only sometimes il get the dash lights turning on and off by themselves,sometimes when cars running theres no dash lights or heaters.
    Also when i turn the ignition on the fan kicks in,then go's off then on again randomly,also the handbrake light and the battery light constantly flash when ignition is on......any ideas?
  2. JohnS3
    JohnS3 Active Member
    3,032
    Sounds like you need a diagnosic scan, this should reveal a list of issues and you can go from there.
  3. vw754
    2,354
    58
    18043 powertrain data bus missing message from A/C controller p1635--000--
    17978 engine blocked by immobilizer p1570-000- intermittent THIS CAME UP WHEN I TURNED ON THE IGNITION AND NO DASH LIGHTS LIT UP AND I TRIED TO START THE CAR.....WHEN I TURNED OFF IGNITION AND RETRIED IT STARTED OK.
  4. NHN
    29,596
    1,782
    Wonder if you've got a dodgy immo chip or the barrel & coil are faulty, what about your 2nd key?
    2nd thoughts make me think barrel as this would affect dash not lighting up properly given it switches several circuits on at varying positions.
  5. vw754
    2,354
    58
    what about the first code 180 43 ?
  6. NHN
    29,596
    1,782
    Could be because the immo issues mate, clear it & see if it returns on a **** startup.
  7. vw754
    2,354
    58
    This is all i keep getting after i clear the codes, 18043 powertrain data bus missing message from A/C controller p1635--000--intermittent
  8. VRStu
    VRStu Just Looking VCDS Map User
    1,073
    Have you tried the second key as Nigel suggests?
  9. vw754
    2,354
    58
    YES but if it were the key i wouldnt start and soon as ignition is on or car is started fan kicks in coming on and off randomly,battery light flashing and handbrake light flashing and just this 1 fault
    A/c controller is that air-con ? is that why fan is kicking in?
  10. Khufu
    Khufu Well-Known Member
    5,704
    31
    I'd disconnect the power connector to the rear tailgate lock. Scan/clear & see if what it says incase there is a short feeding back along the canbus. I'd also try to tell the car you dont have any aircon in the central electrics module too and see what it says.
  11. NHN
    29,596
    1,782
    As the barrel switches several circuits & you have had an immo error I'm thinking it could be this given all the fairy lights you're getting cause if those circuits are shorting then it could be turning things on & off which would cause these IMHO mate, its speculative but thought process is possible from my knowledge of the barrel circuits from my RS4 Start Button mod.
  12. vw754
    2,354
    58
    i see what you mean nhn,what i dont understand is i ive had immob error today but the dash lights were playing up yesterday,is the barrel expensive and a difficult job? im surprised no one can pinpoint the faultcode, 18043 powertrain data bus missing message from A/C controller p1635--000-- air-con?,if the fan kicks in with ignition and keeps coming on and going off could this be a fault with the air-con system? i dont want start replacing the barrel for nothing,but hey got start somewhere
  13. NHN
    29,596
    1,782
    Given the errors present with these issues it would seem related & given the ignition systems switch everything on then it could cause all kinds of issues, I've got a steering column with barrel etc still attached I had leftover from some parts I bought ages ago, fits an a3 04-07 certainly way cheaper than dealer if interested to work with, of course you'd need to swap parts over from old barrel but you'd have to do this anyway huh, just this route is cheaper & climate issues wouldnt IMHO cause the dash to keep flashing away like an xmas tree, but happy to be proved wrong, climate faulty isnt exactly that cheap to replace either.
  14. Khufu
    5,704
    31
    I take it its not actually the barrel you mean, its the elecrical connector that the barrel turns LOL. Athough not having looked they may be one piece though I hope not or out comes Mr drill.
    I've seen fauly connectors behind the barrel before, usually its the starter that no longer works probably due to a bit more load going through it?
  15. NHN
    29,596
    1,782
    Barrel, ignition, same thing to me when its all in the same casing matey, lol
  16. vw754
    2,354
    58
    Tuesday,19,January,2010,19:51:20:18030
    VCDS Version: Release 908.0
    Data version: 20090911
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 7D
    VIN: WAUZZZ8P
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Cannot be reached 1100
    09-Cent. Elect. -- Status: Cannot be reached 1100
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Cannot be reached 1100
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: Cannot be reached 1100
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: Cannot be reached 1100
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 1110
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: Cannot be reached 1100
    72-Door, Rear Right -- Status: Cannot be reached 1100
    7D-Aux. Heat -- Status: Malfunction 1110
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 FF HW: 028 101 190 5
    Component: R4 2,0L EDC 0000SG 6337
    Revision: 12345678 Serial number: AUX7Z0E1FNG04N
    Coding: 0000072
    Shop #: WSC 06314 000 00000
    1 Fault Found:
    18043 - Powertrain Data Bus: Missing Message from A/C Controller
    P1635 - 000 - -
    Freeze Frame:
    RPM: 0 /min
    Torque: 6.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.16 V
    Bin. Bits: 00000100
    Bin. Bits: 00000000
    (no units): 144.0
    Readiness: 0 0 1 0 1
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0104
    Coding: 0023174
    1 Fault Found:
    01314 - Engine Control Module
    013 - Check DTC Memory
    Address 08: Auto HVAC
    Cannot be reached
    Address 09: Cent. Elect.
    Cannot be reached
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
    Component: Airbag 9.41 H10 3230
    Revision: 91H10323 Serial number: 003620028UHP
    Coding: 0034622
    No fault code found.
    Address 16: Steering wheel
    Cannot be reached
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 981 A HW: 8P0 920 981 A
    Component: KOMBIINSTR. VDO H73 0300
    Revision: D04 Serial number: 2241ED04006344
    Coding: 0004443
    Shop #: WSC 00047 210 62144
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 D HW: 1K0 907 951
    Component: Gateway H08 0100
    Revision: 08 Serial number: 2500105208043E
    Coding: 3D3F0B42072103
    2 Faults Found:
    01336 - Data Bus for Comfort System
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 86
    Mileage: 133116 km
    Time Indication: 0
    Date: 2010.01.18
    Time: 23:02:13
    00470 - Combination comfort Databus in Single Wire
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 46
    Mileage: 133116 km
    Time Indication: 0
    Date: 2010.01.18
    Time: 23:03:49
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Revision: D04 Serial number: AUX7Z0E1FNG04N
    Shop #: WSC 00000 000 00000
    Address 42: Door Elect, Driver
    Cannot be reached
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K2 909 144 H
    Component: EPS_ZFLS Kl.7 1502
    1 Fault Found:
    00750 - Warning Lamp
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Mileage: 3080 km
    Temperature: 26.0°C
    Voltage: 13.10 V
    Voltage: 12.90 V
    Address 46: Central Conv.
    Cannot be reached
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P4 035 382 HW: 8P4 035 382
    Component: AB2 SUBWOOFERBOXH03 0180
    Revision: 00002 Serial number: 10000001230153
    Address 52: Door Elect, Pass.
    Cannot be reached
    Address 56: Radio Labels: 8P0-035-1xx-56.lbl
    Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
    Component: concert II EU H51 0100
    Revision: 01S Serial number: AUZ2Z3E2059450
    Coding: 0001001
    Shop #: WSC 06435 000 00000
    1 Fault Found:
    00466 - Control Module for Steering Column Electronics (J527)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 5
    Fault Frequency: 254
    Reset counter: 86
    Mileage: 133092 km
    Time Indication: 0
    Date: 2010.01.18
    Time: 21:07:25
    Freeze Frame:
    Bin. Bits: 10
    Address 62: Door, Rear Left
    Cannot be reached
    Address 72: Door, Rear Right
    Cannot be reached
    Address 7D: Aux. Heat
    Cannot be reached
    End ---------------------------------------------------------------------
  17. JohnS3
    3,032
    Mmmm, you might have a break in the CAN bus as you can't talk to many of the modules in the car. What happened before it started to do this?
  18. vw754
    2,354
    58
    dash showed boot lid as being open, then alarm,then it was,gauges on clocks/dash ,then 1 fault after another,car has been parked for 6days without moving when it was -8 in ice/snow,before that it was 100% drove it for an hour yesterday drives ok. Took bootlid lock/latch off wd40'd it put it bag plugged connecter back on and was still showing boot as open so i ordered another lock but never got round to picking it up/fitting it.
    What can i do now any ideas ?
  19. JohnS3
    3,032
    I wonder if your central electronics unit is damaged? But I'm just guessing here, I think it needs someone with specialist knowledge.
  20. Broken Byzan
    13,244
    468
    Damp in the unit?
  21. NHN
    29,596
    1,782
    TBH if a module cant be reached it would suggest either canbus not working so damaged wire or no power to those modules, it could be an issue with the barrel/ignition, the can gateway module behind the glovebox, as the gateway module runs the bus anyway iirc, I am not convinced its the 09 central electrics board atm, but as Mark says it could be weather related, you are going to need elsa & maybe some 2nd user module/s to swap to test.
    You could try disconnecting some modules & see if the rest start working again, but remind me, it starts every time without fail?
    Welcome to ring me to go through it.
  22. Khufu
    5,704
    31
    I know its probably patronising but have you checked ALL the fuses?
  23. NHN
    29,596
    1,782
    The thing is Ew the systems come on/off so IMHO it wouldnt suggest a fuse as these just wouldnt work full stop, but it wont hurt to check every fuse with a meter given 5 minute job.
  24. vw754
    2,354
    58
    The auto electrician has checked the micro switch which is fitted in the bootlock and said its working,for some strange reason the plug with the 3 wires which plugs into the bootlock/microswitch is still sending a signal when the boot is shut.
    Electrician has said this wire should go dead when the boot/tailgate is shut but for some reason it isnt,also when he put a probe/multimeter and was checking the wire plug, the clock/dash gauges started going funny again the stopped...he said its damp or maybe central covenience unit is the problem,causing all the electrics to go mental!
    Ive bee told to drive the car regular incase its damp.......Because when i started the car this morning and drove to the electrician (6 miles away) car was NORMAL! no issues whatsovere and now ive drove back with no problems..........just the ''boot open'' pic in the dash...........all faults have been cleared and only 1 keeps coming back up
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 46
  25. NHN
    29,596
    1,782
    Assuming that error is still from the gateway, the convenience module is actually in the bottom right hand corner of the boot, have to take the rear plastic boot trim that goes along the back edge & then the right side trim to get to it, maybe its got damp in there mate, have a look, if you can check the part number on the module, then I have a spare one here if needed to test.
  26. vw754
    2,354
    58
    car is back to 100% ive now found the seal around the tailgate isnt on properly(what a difficult pain in the ar*e to fit ! and sparewheel well was a small swimming pool,got clean up 2morrow,connector plugs wont come off from the covenience unit,i bet theyre corroded or something...going pullem off give em a good clean anyway.
    Part number for unit is :8p0 959 433 C
  27. NHN
    29,596
    1,782
    Well done mate for perservering, you sure you're pushing the clips in enough to release the connectors mate, if you are then you could be right & its been shorting out from water & corrosion, mine is 8P0959433 which superseded to the C so its compatible, so if the unit is buggered then PM me & we can do a deal.
  28. vw754
    2,354
    58
    Thanks nhn at the moment all is 100% working fine,i also found the rear washwipe pipe had somehow come off inside the boot next to the 1/4 panel,it was a ****** to clip back in but all is good now,couldnt get any connecters off so ive give a good wd40 squirt in the plugs which should drive out any moisture.
  29. vw754
    2,354
    58
    still cant fighure out why this fault keeps coming back up though, only thing ive noticed is.........u know when you use the front winscreen washers and the wipers come on and sweep the screen 3 times then rest then after 5 seconds they come back for 1 final sweep?.........that dont work anymore ! (the final sweep bit after 5 seconds)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 46
  30. jav786
    jav786 Member
    123
    I had the same problem with my BOOT. the alarm kept goin off every 20 minutes.
    the boots and doors have sensors in themm, if the boot is comin up as open on the dash then its your boot locking mechanism i had the exact same problem, brought 1 from audi RRP = £30
    and now alarm dont go off at all.
    i have the part number in my car, ill put it up later.
  31. Khufu
    5,704
    31
    I'm sure that that is a function that can be coded on & off by VCDS, why its now off is odd though.
  32. vw754
    2,354
    58
    any ideas on codig....so i can check to see if its still coded?
  33. Khufu
    5,704
    31
