ill fitting rear light clusters
Mick Rowley Mar 7, 2012
  1. Mick Rowley
    Mick Rowley New Member
    Help, my rear light clusters don't seem to fit very well, there is a big gap between the body work and the actual light cluster so when it rains or i go through the car wash water enters the boot area and the the wiring loom gets wet. Is there supposed to be a seal around the units or are they the wrong lights???????
  2. audicruiser
    audicruiser Audi Heaven
    1,865
    Is it a Sportback or 3 door? Either way the light should be flush with bodywork. If its a Sportback, check the two locating lugs at the front of the unit are pushed home into the rubber grommets...
  3. Paullie
    Paullie Banana Menace! VCDS Map User
    2,076
    288
    If it's a 3 door, it could be that some of the rear bulbs have had to be replaced and whoever has done the job hasn't refitted the lights properly. Best thing would be to remove them - very easy job - and try and fit them perfectly flush, so no more water gets in. :wub: xx
    andyam likes this.
  4. chrisb72
    chrisb72 Active Member Team Panther Audi S3
    237
    72
    I have recently had a new LED cluster set fitted to my Sportback and have noticed a very small amount of water build up around the bottom of the lights, but as far as I know this isn't going into the boot.
  5. plezz
    plezz Member
    233
    9
    might be worth putting some pics up too in case it helps - might give people on here a better idea what the prob is caused by.
  6. hades-
    9,482
    646
    as above stick a few pics up
    cant really advise without seeing the problem
    has it been this way sinse buying the car ?
    could be simple refit or a bad repair
  7. jb0o
    jb0o North East Forum Moderator Site Sponsor Regional Rep VCDS Map User
    2,664
    118
    Lugs may have snapped off
  8. plezz
    plezz Member
    233
    9
    are they OEM? could be oddly shaped aftermarkets.
  9. NHN
    29,577
    1,779
    Yes as said, before we can advise, ideally need pics of them fitted & the rear of the lenses so we can ascertain if anythings missed or out of spec.
  10. Mick Rowley
    i will try and put pictures up. I have had the o/s rear light off and it seems to go back on ok but still a quite large gap between body work and light, i have noticed the boot lid isn't quite flush with the lights either, i checked to see if it was an insurance write off, stolen or scrapped but it came back clean, it does look like a repair ov somesort has been done but not very well and the paint job isn't the best either
  11. hades-
    9,482
    646
    cant really advise untill we see the pics
    it may have been damaged and not claimed on insurance
  12. Mick Rowley
    how do you get pictures up?, i've taken some and sent them to facebook but cant seem to get things to work right, sorry but not a techno geek
  13. MTRL
    MTRL Split Grill!
    459
    52
    When I bought my car a few months ago one of the rear lights had a small gap between the bodywork and housing. I just tightened up the hexagonal screw, behind the light in the boot. This pulled it back into place.
    Try that, if not I would try taking it off completey so you can see how it all fits to the car and see if anythig is stuck there or bent. There is not much that can go wrong back there, just 2 points that pop into place and the screw in the back. (Thats what she said).
    Some photos and advice on removing on some other forum:
    Rear Lights - Removal, how the hell?? - uk-audis
    Advice on uploading photos
    http://www.audi-sport.net/vb/welcome-section/127616-how-post-pictures-forum.html
  14. Mick Rowley
  15. hades-
    9,482
    646
    make it bigger
  16. Sidhu88
    Sidhu88 Active Member
    808
    76
    Thats what she said....
    sachen likes this.
  17. NHN
    29,577
    1,779
    Not the best pics tbh but alas, need to ee the boot lines from the rear not the side to see the degree of bad fitment & distance pics, not nose to the lense.
    TBH it doesnt look as bad as you make it to be.
    But, check the rubber grommets on the side of the car, that the rear light ball joints push into, havnt pushed into the cavity of the chassis, common to happen when not being careful or fitting properly.
    You can also stick some say fabric cloths strips (coroplast) onto the paintwork, build it up behind the lights so it stops it from rocking/piveting against the car as such & then also pushes it out a bit, at the bottom below the main hole where it bolts on with the plastic nut.
  18. hades-
    9,482
    646
    prob had a smack and **** repair
  19. Mick Rowley
    thats what i'm starting to think, but no record of any accident involvement, thanks for the help its been very helpful
