Ignition Power for Stereo on Concert...
itssam Jan 30, 2009
  1. itssam
    itssam A3 3.2Q Sport
    73
    Hi Guys,
    I'm trying to get a ignition signal for my parrot hands free, it seems that theres not an ignition power going into the basic concert, it seems there is a Phone and satnav output from the radio, but i think they are both constants also?
    Is there anything i can pull from the radio for ignition power or do i need to grab a line from the fuse box and if so does anyone have a recommendation for where to pull it from?
    Sam
  2. Issac Hunt
    1,162
    Using a feed from the fusebox is the easiest way.
  3. itssam
    73
    boo :( might have to pick up a piggyback fuse thing.... any recomendations on which fuse to use?
  4. h5djr
    9,311
    1,689
    I have a MicroGo Speed Camera locator which is wired to come on with the ignition and I have it connected to fuse position 45 in the fuse box at the end of dashboard.
  5. VRStu
    VRStu Just Looking VCDS Map User
    1,073
    There isn't a switched live behind the radio as it it switched by CAN.
    As Isaac says the fuse panel is your best bet. If you want a neat job you can use a repair wire in the back of a spare slot.
  6. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    これで、ここでは、少数の歴史と語ったが必要だ 無名の英雄 この土が削除されます ある人は、継承はされています 造幣局からの輸入 人々の多くがないのにネウルエウンイ 事実、この老いたहेごみमेरे 彼は帽子にゴミ収集した これは、うわっイレオルスがズボンです そして彼は、フラットに住んで協議会
    彼は'真のनानाである 大きな皿の後に起動チクヒギル 彼はउन्हें得ることができる職業を持って 彼は根が何उन्हेंデイジー電話
