Ignition module?
Aaron1.8t Mar 20, 2013
  1. Aaron1.8t
    Aaron1.8t Member
    146
    13
    Hi guys,
    had my 1.8t agu for a few months now...
    Today i put a cone filter on it.. But theres a ignition module i believe its called on the airbox.
    I left it tied to a pipe with both connectors connected.. What is it?? Car wont start when unplugged. What have u lot done with it?
    Also car flutters now so looks like a faulty diverter valve??
    any help pls
    thanks
  2. Lemon S3
    Lemon S3 Alex
    1,390
    41
    You're not talking about the MAF are you? Can you take a picture of it?
    If it is the MAF, you're going to want to put that back.
    Check the small vacuum hose on top of the dv is connected properly and isn't split.
  3. <tuffty/>
    21,967
    4,243
    AGU's have an ignition amp.. this is normally fitted to the airbox.... as long as its secure then it should be fine... you can cable tie it to something (alloy bit facing out as it gets warm) or make a bracket to attach it too
  4. Jay A3
    Jay A3 #because Racecar Team Daytona Audi A3 Manual
    2,131
    358
    +1 as per tufftys post
    The metal bit acts like a heat sink
  5. Aaron1.8t
    Aaron1.8t Member
    146
    13
    Ahh cheers tuftty!! Thats wot i did. Also flutter?? New diverter valve?
  6. <tuffty/>
    21,967
    4,243
    Assuming its plumbed in right... is it an OEM one or aftermarket one?
  7. Aaron1.8t
    Aaron1.8t Member
    146
    13
    Its a OEM one... Looks very old n dirty so might need changn.. Ill change it n see.
    thanks for the reply guys.
