Ignition Live & Felt Tape
Pinknoise Jun 5, 2009
  1. Pinknoise
    Pinknoise Cock in an Audi
    21
    This is a double quesiton, hopefully easy ones.
    Is there an ignition live I can pick up somewhere in the boot of a 2005 A6 (C6)?
    What is the correct name for the felt tape the manufacturers wrap around the original cables?
    Sam
  2. frenchy2475
    frenchy2475 Tetbury Audi Parts Man
    263
    000 979 950 is the part number for the tape from your local dealer £4.29 +vat for a big roll. Not sure about the live pick up??
  3. AndyMac
    9,832
    45
    Also depends on what you're planning on running from the ignition on live.
  4. Pinknoise
    21
    A relay.
    Then two 50Ah sealed lead acid batteries, so they charge when the engine is running.
  5. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    Where are you going to take the main power line from?
  6. Pinknoise
    21
    The battery beside the spare wheel.
  7. Caesium
    4,879
    OIC
  8. NHN
    29,295
    1,701
    Fuses 1-11 are ignition ones, so take a spare fuse & use repair wire for trigger of relay.
  9. AndyMac
    9,832
    45
    Presumably this is to run a high power amp, so why not just use the remote on from the HU?
  10. Pinknoise
    21
    No, lead acids are for camping. Running fridge etc. I know its not really camping if when you bring that sort of stuff but i don't care.
    How would I pick up a remote from a MMI Low system? Actually can I pick up RCA outs awywhere as well? I have two pair of Pioneer PRS Components, sony 4 channel, sony 2/1 channel and a pioneer slimline sub that came out of my Passat that are begging to be used.
  11. Caesium
    4,879
    Get a small generator, much better.
    I have a 750watt one I no longer need....
