If I get con rods done, what else is needed/advisable/desirable?
Nogmeister Feb 11, 2013
  1. Nogmeister
    Nogmeister Member
    287
    Can anyone help? I'm an utter noob when it comes to engine internals.
    I have been told that I may need a new turbo in the not too distant future, so that may as well be a hybrid or maybe big turbo.
    Now I understand that the con rods are like toffee, so I was thinking of having them done. I have an Audi/VW mechanic that does cash work, and he has suggested these bits:
    Connecting rods
    Head gasket
    Head bolts
    Big end bearings (check and replace if needed)
    Crank (check and replace if needed)
    Is there anything else to think about? Its an AMK lump with 80k on it.
    Cheers!
  2. <tuffty/>
    21,805
    4,173
    Head gasket
    Cam cover gasket
    VVT gasket set
    Head bolts
    Rifle Drilled rods
    Big end shells (replace, do not reuse)
    No need to buy a new crank
    Rings... light hone of the bores for a deglaze, gap rings and run in..
    Cam belt
    Water pump
    Tensioner pulley
    Tensioner damper
    Gaskets for anything else you remove like the turbo, oil and water lines etc... if its got a gasket or a seal and you remove it, replace it... it will only bite you in the ****...
  3. s33nyboy12
    s33nyboy12 Well-Known Member Audi RS5 Owners Group Navarra Blue Classic
    1,496
    210
    Go on then........ Someone price this up?.... Rough guide??????
    Sean
  4. Nogmeister
    Nogmeister Member
    287
    Cheers Tuffty mate.
    So is it basically an engine health check and rebuild?
  5. <tuffty/>
    21,805
    4,173
    If you are gonna do it then do it right IMO... I have paid the price of not doing all mine at the same time but its worth doing tbh...
  6. Nogmeister
    Nogmeister Member
    287
    Makes sense TBH. Would you be able to think of a ball park figure for the parts only, from your experience?
  7. <tuffty/>
    21,805
    4,173
    Millions.....!!!
    Rings can be the most expensive bit but there are places where you can get rings cheaper from what I have seen but I'll have a stab...
    Head gasket (elring) - 25
    Cam cover gasket - 16
    VVT gasket set (genuine) - 5
    Head bolts (genuine or elring) - 30
    Rifle Drilled rods - dunno... Bill has these in stock though
    Big end shells (replace, do not reuse) - 60 to 80? Bill has calico performance shells in
    Rings... VAG ones are 30-40 per piston
    Cam belt - 15?
    Water pump 30 ish (exchange typically)
    Tensioner pulley - can't remember
    Tensioner damper - around 40 ish
    All prices are approximate and maybe a little on the low side on occasion as I do get trade prices but if you source from a combo GSF/ECP and Dealer/TPS then you should get a fair price...
    Forgot to mention, oil and filter plus some G12 coolant
  8. Nogmeister
    Nogmeister Member
    287
    Blimey, so quick tot up is £900 ish, counting £395 for the rods, £35 for the tensioner pulley, and £100 for oil, filter and G12.
    Wow, so realistically this is looking to be a £2k job pretty quick, unless I get very handy with the spanners!
  9. s33nyboy12
    1,496
    210
    This is what I was thinking nogmeister, labour intensive and a killer on the pocket, the only way I could warrant this is if my cam belt and water pump was due!
    Sean
  10. Nogmeister
    Nogmeister Member
    287
    Parp! Does make me wonder if I could do it though, or most of it....
  11. Scullies
    Scullies Well-Known Member
    1,543
    658
    May as well get a new drive/accessories belt too and dont forget get a new clutch & slave cylinder because the stock one wont last long on the hybrid/BT.
  12. Nogmeister
    Nogmeister Member
    287
    Single mass flywheel and clutch done last year, but defo a good shout mate cheers
  13. Yohan87
    Yohan87 Guest
    I posted a thread up somewhere with all the prices, quick search should reveal it.
    Bill does an all in fitting price which is very reasonable, give him a shout :)
  14. Yohan87
    Yohan87 Guest
    Lifted from this thread.
  15. Nogmeister
    Nogmeister Member
    287
    Nice one Yohan, I'll have a closer look through that cheers pal
  16. Prawn
    11,641
    3,636
    Apart from Yohans list, where it might get missed, nobody seems to have mentioned an oil pump.
    If you're pulling it all apart, I'd say a new oil pump is fairly essential.
