IDLE speed BKD engine
sprout99 Jul 23, 2008
  1. sprout99
    sprout99 Member
    373
    Does anyone know what the range of idle speeds is for this engine?
    Also, using Ross Tech what is the correct blocks to check and how do you increase or de-crease the idle speed?
    Ian
  2. RobinA3
    RobinA3 Well-Known Member
    1,827
    47
    At a guess i think the idle speed should be between 700-850rpm
    You won't be able to change the idle speed as its a part of the ECU engine map.
    You'll only be able to monitor it using Vag Com with one of the meaurement blocks.
  3. golf
    golf ***** rent boy VCDS Map User
    1,556
    Try getting Lemmiwinks, I think you can adjust the idle through there, though I'm most probably wrong.
    Decent guide
  4. kaz219
    kaz219 Active Member VCDS Map User
    1,808
    Just hada heart attack!
    I just walked out to my drive way to check the idle speed on mine....But my A3 wasn't there!
    .....Then i remembered its gone to have its Cambelt done! Phew lol
    But i'll check it tommorrow when i get her back but RobinA3's guess seems about right.
  5. sprout99
    sprout99 Member
    373
    it can be done
    the garage have raised it twice but i still thjink it's a little low
    the aircon being used when engine is cold causes a splutter.
    Not as bad as it was ...
