Idle Raising from 800rpm to 1100rpm by itself ( VIDEO)
Rider4life Oct 22, 2013
  1. Rider4life
    Rider4life Member
    72
    Does this mostly everytime i drive it. If you turn the car off and start it again it goes back to normal idle or sometimes if you rev the car it drops back down. Anyone know the reason or solution for this?
    I got the heater on full in this video but it does it when nothings on. Just to clear that up.
  2. JJ.Foulds
    JJ.Foulds Well-Known Member
    1,263
    176
    WOOOAH, it starts going crazy half way through.
    i think you got gremlins pulling on accelerator in there mate.
  3. kanecullen89
    kanecullen89 Active Member
    569
    160
    43
    Is it a 170 with a DPF? Engines with a DPF rev higher on their own when regenerating
  4. Rider4life
    Rider4life Member
    72
    Its only the first seconds of the video i'm talking about haha. Its a 140 no DPF.
  5. kanecullen89
    569
    160
    43
    Hmm. When I had my A3 140 I had to get the intake manifold flap replaced.
    It wasn't causing this issue, it just threw up an error, but I suppose it could cause these sorts of symptoms. It's a common fault
  6. bigal23
    bigal23 Member
    208
    I had this on my 140bkd clean everything out all the intercooler pipes and intercooler intake manifold even the intake holes on the head also fit a catch can or block off the ccv that goes in to the air intake
  7. bigal23
    bigal23 Member
    208
    also I did change injectors and that help massively with some little problem I had I think changing injectors after 80-90k should be done on these bkds
