Idle problem.
A3tell Jan 21, 2010
  1. A3tell
    A3tell Member
    239
    just wondered if anyone else has had idle problems with their agu 1.8t??? Its been doing it for about 3 weeks now, ever since i had to change my alternator, wot happens is that when the car is warm and sat still its fine but if i rev a little, the idle will hunt below 1000 for a few seconds then settle back at about 1050, unfortunatly i dont have access to vag-com but would appriciate any input anyone has. cheers.:keule:
  2. HTC
    HTC Active Member
    3,428
    9
    The AGU engine should idle between 800 and 900 rpm. Yours is idling a little high. I would first check for vacuum leaks at the pipes underneath the inlet manifold as you've been working in that area. Is the throttle cable adjusted correctly? Also try a quick throttle body alignment by switching on the ignition without starting the engine. Don't touch the accelerator pedal and wait for the buzzing at the throttle body to stop during alignment.
  3. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    Check PCV hose coming out of the bottom of the inlet manifold as a first port of call.....
