Idle issue 2.0T FSI
JPK Jun 25, 2012
  1. JPK
    JPK Active Member
    303
    Have been having a minor fluctuating idle issue. Sounds like a slight miss and revs drop a little every 10 seconds or so.
    Am getting the following fault codes: P2187, P0441, P3138, P2008
    I reset fault codes and the CEL returned after 100kms approx. Car has done 109,000kms (65,000miles or so).
    I am running a stock map as I want this fixed before tuning.
    Have replaced the following in last 1000kms.
    1. Updated to OEM rev D diverter valve
    2. Deleted PCV with BSH PCV Fix
    3. Replaced spark plugs & coil packs (both OEM)
    I have googled these fault codes and it points to these parts:
    06E906517A - EVAP Purge Valve
    06F133482E - Variable Intake Manifold Adjusting Solenoid
    I guess my question before I replace parts blindly is: Has anyone else had similar issues? What caused it and what fixed it?
    If I replace those parts are my problems likely to be fixed? I am potentially talking about two seperate issues here, as I have no idea if those parts with the fault codes are causing the idle fluctuation or if its possible carbon buildup on valves and therefore possibly unrelated to the Purge valve and the intake adjusting solenoid.
  2. mjr901
    mjr901 Guest
    Have you checked the MAF?
  3. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    Yes, unplug the MAF to see if performance changes. If it does then it's likely MAF is faulty.
    Could be the intake manifold solenoid if all gunged up with oily residue.
  4. JPK
    JPK Active Member
    303
    Sorry, forgot to mention that. Yes it has been checked - replaced with a new one to see if there was a change. No change.
    The idle issue isnt THAT bad and has improved since I had a cylinder 2 misfire and replaced all the coil packs a few weeks ago.
    Its a new set of fault codes now and I am simply wanting a car that idles nicely like it has just been driven off the showroom floor.
  5. MrLapou
    1,233
    121
    In that case, may be injectors need cleaning
  6. JPK
    JPK Active Member
    303
    What is the process to clean injectors on an FSI?
  7. _G_
    _G_ Active Member
    876
    To clean the injectors you can lob a can of BG44k in the tank... I've never been one to vouch for chemicals.. I think the best way is for a good old fashioned clean out by taking things apart and doing it... but I used BG44k at 40k miles and then again at 60k miles and im pretty sure its done a good job... i had a look see and it was all somewhat cleaner and slightly quieter...
    As for the idle and fault codes... i had p0441 (evap) code and i changed my n80 valve... problemo solved... smoother idle and better mpg.. the old n80 had seen its days @ 60k miles! thats the first thing i would try.. its not something you can give a clean so just replace it.. and its a cheap fix.. easy to DIY... clear the codes and see what happens... second option... having failed this... consider the throttle valve adaptor / throttle valve control module
  8. JPK
    JPK Active Member
    303
    Will merge my two threads...
    Thought I had this fixed but its back again. Symptoms are an intermittent idle pulsing between 700-900rpms and car shaking slightly as it does this. Half the time its fine. No fault codes presently but when hooked up to VCDS is showing low voltages to cylinder 2 & 3 (from memory). Engine is AXX.
    Have done a quick check for any split hoses, coil packs are pushed in and seated properly, spark plugs are in correctly.
    Have replaced in the last 2 months:
    Spark Plugs (OEM)
    Revision F Coil Packs
    N80 valve
    Fuel filter
    Cam follower
    Revision D diverter valve
    Oil/filter
    Replaced the fuel filter and n80 last week and as soon as the car was started up it idled perfectly. Then after a 10 minute drive when it was idling the issue presented itself again. Very strange and annoying.
    It gets expensive from here on in (unless I just put up with it as its not THAT bad). HPFP, intank pump, variable intake manifold adjusting unit, injectors & cleaning carbon buildup on valves would be my next step.. So if anyone has any other ideas?
  9. Rhyso
    Rhyso Well-Known Member
    1,514
    312
    Have you replaced the PCV valve? That can give erratic idle I believe but it normally idles higher rather than low if it is shot :think:
  10. JPK
    JPK Active Member
    303
    Have a BSH PCV fix so it rules that out.
  11. MrLapou
    1,233
    121
    Try this, take off the fuel filter, then put the same one back on.
    Could be a fuel issue with the fuel blockage or the tank pump.
  12. _G_
    _G_ Active Member
    876
    Have you tried cleaning out the Throttle Body/MAF?
    Once you have done that it is dead easy to re-set: http://www.google.co.uk/url?sa=t&rc...zYGICg&usg=AFQjCNHLRQpxFpLKCwdk3azM2mjOehHl9w
    IIRC, The other way to reset it is to:
    1. Eninge off key in - don't turn it just put it in
    2. Press down Accelerator down and keep foot down
    3. Turn key to accessories mode
    4. Holding foot down on accelerator for 6 seconds
    5. Turn key off and take foot off acc.
  13. JPK
    JPK Active Member
    303
    Yes the throttle body was 'realigned'/reset with VCDS at the same time as the fuel filter & N80 valve (which temporarily fixed it).
    MrLapou: What will that achieve RE fuel filter? Are you saying it might temporarily fix it again? Therefore suggesting there is a fuelling fault? Is there any way to test for blockages and test the tank pump?
  14. MrLapou
    1,233
    121
    Yes testing to see if the filter makes a difference. It could be the new filter is blocked with crud.
    Only way to test fuel lines is by using specialist pressure and flow equipment.
  15. JPK
    JPK Active Member
    303
    Sorry, im still a little lost. So I replaced the filter with a brand new one and you're suggesting there might be **** in the tank that is causing it to block up again quickly even though its brand new? What would taking it out and putting it back in achieve?
  16. TFSIer
    TFSIer 2.0TFSi Sport Sportback 2006
    39
    I have had P2008 and P3138 codes constantly now for a couple of years. Clear them down and come back on next drive. Car runs fine apart from occasional 'hunting'/misfire when idling, similar to what you describe. Not got any worse over time.
    Advice/research points to Intake Manifold Flap Motor needing replacing :-
    P2008/08200 = Intake Manifold Flap Motor Open Circuit or Intake Manifold bank 1 electrical malfunction upper limit exceeded
    P3138/12600 = Intake Manifold Flap Control Difference or Intake manifold runner control regulation deviation not a plausible signal
    See DIY: Intake Flap Motor Replacement and Intake Manifold for AUDI A3 (8P1) 2.0 TFSI - from 09.2004 200 hp – Spare car parts for AUDI - Engine - Engine Air Supply
    JPK likes this.
  17. _G_
    _G_ Active Member
    876
    sometimes the intank fuel pump filter sock gets knackered but i doubt that would be an idle issue per se... that would probably be more of a hard start issue/youd perhaps notice a change in mpg and the vcds measuring blocks.
    - Idle control vavle/sensor?
    - Ignition timing?
    JPK likes this.
  18. JPK
    JPK Active Member
    303
    Thanks for the advice re intake flapper motor. Will replace at some point. Interesting that those fault codes havnt come back on yet in my case though. Will see how I go over the next few hundred kms.
  19. MrLapou
    1,233
    121
    You changed the filter and N80 which improved things albeit for a short while, so it's logical to assume these items are in the loop causing the fault.
  20. JPK
    JPK Active Member
    303
    Still havnt had any fault codes re appear. Idle issue is back.
    Its got to have something to do with the fuelling system. What is the part number for the in tank fuel pump on an AXX engine?
  21. JPK
    JPK Active Member
    303
    Got the number. Going to change in tank pump, hpfp and run an injector cleaner and see where it ends up.
  22. gdbarratt
    gdbarratt A3 Sportback 2.0 T FSi
    67
    I have just developed same issue.
    Error codes showing are - P1093, P1297 and P0299
    The car had its Coil Packs done by Audi as part of a recall 18 months ago and the plugs were replace by Audi 12 months ago.
    Car is a 2005 Audi A3 Sportback 2.0 TFSi DSG with 68k on the clock, FASH.
    I have just put some Unipart Petrol System injector cleaner in the tank to try and clear any carbon deposits.
    The error P1297 seems to point at DV so I assume that's my next step?
  23. MrLapou
    1,233
    121
    Oil filler cap seal sometimes leaks
  24. gdbarratt
    67
    So happy DV valve replaced today and car transformed - so much more power!
    The Diverter Valve was Revision B and the diagphram was hosed, recommend anyone with pre2009 gets it replaced with Revision D. Part costs just £50 and Crewe Audi charged me just £47 to fit.
    The injector treatment seems to have solved the rough running at tickover too, that and a fast blast to clear out the cobwebs!
    Happy man.
  25. mjr901
    mjr901 Guest
    £47 to fit??? I'd have done that for free!! takes longer to take the payment than it does to undo 3 bolts!!
    Glad its solved your problem though! :)
  26. S.
    S. Save the manuals Team Ibis TFSI Owners Group Audi S3 quattro Manual
    2,019
    551
    if it's 2.0 tfsi, then i think it's not as easy as on s3 to change dv.
    glad it's sorted.
  27. Quinny.
    Quinny. New Member
    Hi any body help. I've got an 8p got a little miss fire only on idel I don't feel it when I drive. I have change the plugs. Coil pack. Injectors it is still there. Had it plug in at audi too no fail codes.
