Idle boost reading
sekenzo Oct 4, 2011
  1. sekenzo
    sekenzo Member
    102
    Can someone confirm what is the normal idle vac reading? I am currently at -0.8 bar... Does this sound like I have a leak?
  2. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,183
    Just checked, mine sits at -22PSI.
  3. s3gazz
    s3gazz Well-Known Member
    1,376
    99
    Mine is -20
  4. sekenzo
    sekenzo Member
    102
    -0.8bar = -11.6 psi.. Sounds like something is wrong...
  5. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    I'm on -13.4. I've also been told i have a boost leak but then i've been told everything is fine? Confused.com
  6. 16Klappe
    5,795
    1,183
    To be fair because it is making negative pressure it will be difficult to tell if and where the boost leak is, you will need to have it vacuum and pressure tested.
  7. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    -20 until i drive it a bit then it goes to -25 when i stop
  8. Andy123
    Andy123 Member
    260
    You want around 19/20 inHg of vacuum, anything much lower would suggest a leak. Not measured in psi by the way, -20psi isn't possible.
  9. Westy
    Westy Well-Known Member
    17,443
    1,103
    A lot of guages show hg in vacuum not PSI. mine is around -14hg
  10. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,823
    107
    I was beginning to think i had a problem... Mine has never seen -20 psi !
    I was told mine was "giving a good reading indicating no leaks or problems "
    I will check what it actualy reads later when i head out.
  11. Westy
    17,443
    1,103
    I'm sure this subject has come up before and around -13-14hg was about right :think:
  12. S3 Paul
    2,823
    107
    I was thinking high 'teens
    Different when still on cold start too?
  13. Westy
    17,443
    1,103
    This is mine on cold start then it drops a bit when warm:
  14. s3gazz
    1,376
    99
    When mine starts (cold) it's 12 psi ish then when warmed it goes to 20 psi
  15. Sandip
    2,440
    91
    Mine is -20 in.Hg
    Looking at most boost gauges
    Vacuum - in.Hg
    Boost (positive pressure) - PSI
  16. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    It all depends on the calibration of the guages i mean pay 20 quid for a guage you are hardly going to have lab results.....
    Andy123 is correct, it is shown in HG not psi and all the forced induction cars ive had, it has always shown around the 20 in hg mark on idle, infact i used to use this as a tool if it went closer to 10 in hg, i new i had a leak somewhere, and sure enough there was one...:o.k:
  17. Dani_B19
    9,113
    346
    Mines around the 20 mark.
  18. hades-
    9,481
    646
    -20hg
  19. S3 Paul
    2,823
    107
    Mine sits at about -18 once warm, Goes up ( or down ) to -22 on over run,
